I'm completely new to this and I'm really sorry if I didn't look hard enough in the search to find the answer...
If say I have a video that is hd which is on a higher resolution than standard definition, and I burned it on a normal dvd (ignore disk size issue) and try to play it on a regular dvd player hooked to a standard def TV (not a hi-def player/TV) ... will the video be displayed just fine but "downscaled" (if that's the right word?) to fit the TV screen? .. or will the dvd player simply refuse to play it because it is at a higher resolution?
I'm interested in buying the Philips DVP5982 dvd player (however I don't think my question has to do with this but thought I'd mention it anyway if it does depend on the dvd player). I know it has this 1080p upscaling feature but I'm talking about playing the video on a standard tv not an hd one.
Thank you for your help
If you are thinking about Divx/Xvid then "the dvd player simply refuse to play it because it is at a higher resolution"
Standard DVD players must follow the DVD spec.
See https://www.videohelp.com/dvd
Divx/Xvid playback is spec'd for each machine. Most won't play HD.
For Divx players that will play HD, see this list
http://www.divx.com/products/hw/browse.php?c=7Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
thank you for the quick reply
the video (really is an episode of the office
) is like 624x352 ... even though it says it's supposed to be hd or something :think: ... does that mean it'd play fine seeing it's under the resolution for both ntsc/pal? or do I need to check something else in the video (like how its encoded and what not)? --sorry for the ignorance
thank you again for the reply
624x352 is not even SD resolution so should play
You should get prepared with the tools needed to make such video playable, problems with QPEL and others, your player may quite likely find the video in-compatible. More reading and research might just prevent an unpleasant surprise.
thanks for the advice, i will definitely do some research beforing getting or trying anything
i got a week off without exams and what not so i'll prolly dedicate a day to get to know all i need to know about dvd players and what not ... i love reading 8) lol
How live capture 3 video feeds at the same time (standard def)?
By Frowzy in forum Capturing and VCRReplies: 4Last Post: 12th Aug 2011, 18:27 -
Need a Good Standard Def Digital Camcorder
By faramith in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 5th Jan 2010, 11:21 -
Standard Def DVD Movies With Best Picture Quality?
By avkhatri in forum Off topicReplies: 2Last Post: 8th Jul 2009, 17:29 -
best high def televisions for standard definition input?
By EAO in forum Newbie / General discussionsReplies: 3Last Post: 24th May 2008, 14:15 -
highdef dv or standard def dv
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 29th Feb 2008, 19:37
