Hi!
After spending LOTS of time wrestling with my Pinnacle DV300 card (bought used) and not getting it to work (I have re-installed Win98SE about 15 times due to this!) I decided to buy a plain vanilla Firewire-card. Well, so far so good. My newly installed card works fine, but the captures are VERY big, as most of you know. Captures of 1hr in full DV-qual is about 12GB as most of you know. Does any of you know how to enable compression when capturing using plain vanilla Firewire, I don't want to decrese resolution etc, I want compression... Hins, suggestions or descriptions are all welcome.
TIA
Wintermute
Results 1 to 1 of 1
does capture of firewire use the sound card?
By Cazz in forum Capturing and VCRReplies: 4Last Post: 24th Jan 2010, 17:45 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
Do I need a firewire card to capture video from my miniDV device?
By MPTESE in forum Capturing and VCRReplies: 8Last Post: 16th Mar 2008, 09:55 -
Is a HDMI capture card or firewire better for transferring dvr recordings?
By yoda313 in forum Capturing and VCRReplies: 0Last Post: 9th Dec 2007, 14:42 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
