    Jan 2006
    i was encoding an mkv file (something i do daily, being addicted to fansubs and all) when the file froze at roughly 90% and gave off this error:
    FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
    Wed Nov 7 12:50:57 MST 2007
    Mac OSX universal build for ffmpegX
    libavutil version: 49.0.0
    libavcodec version: 51.9.0
    libavformat version: 50.4.0
    movtoy4m
    Copyright 2002-2006 Johan Lindstr??m
    All rights reserved..
    Input #0, yuv4mpegpipe, from 'pipe:':
    Duration: N/A, bitrate: N/A
    Stream #0.0, 23.98 fps(r): Video: rawvideo, yuv420p, 640x480
    Output #0, avi, to '/Users/******/Desktop/new/aug 6/Charge_Otokojuku_6_[ADTRW].mkv.ff.avi.e.avi':
    Stream #0.0, 23.98 fps(c): Video: xvid, yuv420p, 640x480, q=2-9, 1654 kb/s
    Stream mapping:
    Stream #0.0 -> #0.0
    video:285808kB audio:0kB global headers:0kB muxing overhead 0.286483%
    bench: utime=350.638s
    [matroska @ 0x5597b8]Matroska demuxer version 1 too old for file version 2
    /Users/******/Desktop/new/aug 6/Charge_Otokojuku_6_[ADTRW].mkv: Unknown format
    crc checked out on the file, it plays back fine in both vlc and quicktime with perian. the odd thing is, under the summary tab, when i dropped the mkv in, it said it was unrecognized on both audio and video... strange considering that its just xvid and vorbis. i'll do more testing on it, but i thought it worth pointing out the error.
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    foo.mkv: Unknown format
    Apparently there's a version 1 and version 2, and the latter is not supported.
    Jan 2006
    oh.. well, i guess its a pretty straightforward issue, then. i solved it by running the mkv through my older version of mkvmerge and it squared off the issue, presumably because mkvmerge repackages the mkv into a v1 container?
    regardless, it may be a sign that ffmpegx has gotten a little too archaic in its supported outputs... cant wait to see what major has in store for the next release.
