  1. I catch up on US TV shows via the internet and some are available as HD streams. These come in 100MB pieces which I join together with nullpacketstripper and watch with VLC. I'd like to convert some to h.264/xvid but have had no luck with Handbrake or ffmpegX. Handbrake will accept each individual 1 minute-long file but not the joined leviathan, whether I instruct nullpacketstripper to strip the PIDs or not. Can anyone suggest an alternative means of joining/converting. I have Ubuntu installed if a Linux-based method is available.
  3. Banned
    Freedonia
    Yes, I have a suggestion, but you're not going to like it. It will work though. Install either Parallels or Fusion from VMWare. Run Windows in a VM and convert in Windows. Or run BootCamp and boot Windows and do the work there. I have a Mac at work and they are OK, but to be blunt, some things are just a lot easier to do in Windows. The problem with Macs is that if something doesn't work like you are finding, you probably only have 1 or 2 programs that can do the job and if they don't work you are stuck. At least with Windows there are a variety of programs, including some free ones (I'm thinking of X.264 here) that can encode H.264 or X.264.
    Jul 2003
    at home
    Try Visualhub on your individual clips and turn on the join option. VisualHub joins files after the conversion.
  5. Baldrick
    I tried Streamclip a while ago but I'll have another bash and see what gives.
    jman98
    I don't have any great objection to using Windows but I had great difficulty getting my triple booting system up and running and it was either XP or Ubuntu that had to go....the penguin won.
    JoachimS
    I was intending to use CRF and I imagine there'll be problems with joining files but I'll certainly give it a spin after next Monday.
    Apr 2005
    Blacksburg, VA USA
    If it plays in VLC, why not use VLC to export to MPG?
    Al Bloom
  7. The thing is that I want x.264, otherwise VLC would indeed be a great option.
  8. I was delighted to find that selecting all the individual pieces with MPEG Streamclip caused it to open them as an unbroken stream and I am now able to convert to x.264 with the same tool. I'm used to the relatively idiot-proof nature of Handbrake's options so some of the configuration alternatives are going to require a bit of research.
    Thanks for all the advice offered.
