Ok something weird. It has been now a week that my dvd burner LITE-ON LH-20A1H firmware LLOC is hard to open the tray. I need to hit the open button several times to open. But now here is the weird part, If I record from it, after each recording, it opens with no problem. But when I reboot or start up the PC, I need to hit the button several times in order to open tray. Is my burner dieing? If it is, I just got it 3 months ago. I appreciate any help.![]()
Thanks but it's not that. I use IMGBURN to eject when i read or write a dvd, this just happens when a fresh boot up, or whenever i use it for the first time. But after i start using it, it opens & closes with no problem. It does not want to open unless i hit the open button several times.
The drive is wearing out. Power off fully retracts the tray and its binding. A couple of attempts to open => success. My Lite-On recorder has been doing this for some time. Later symptoms will be needing to push the tray to give it a start at closing.
Optical drives use a cheap plastic gear to move the tray. The plastic wears and develops problems moving the tray.
Panasonic S97 tray will not open
By southland66 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Nov 2011, 02:24 -
LITE-ON LH-20A1H Problem
By mn072065 in forum DVD & Blu-ray WritersReplies: 11Last Post: 12th Jul 2008, 14:02 -
Problem with Norcent DVD Player, Tray keeps open/closing, tray disc error
By daveshostack in forum DVD & Blu-ray PlayersReplies: 3Last Post: 12th Feb 2008, 12:41 -
Samsung HD960 Tray stays open
By tommcd64 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 29th Jan 2008, 10:40 -
liteon disc tray will not open
By northy44 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Sep 2007, 08:20
