Hi
ripped a movie with smart ripper and dvd2avi as i have done before.
on this film i am doing, tmpgenc wont open the ac3 file.
I get not supported or cant open.
I have never had this problem before.
This happens on all 3 ac3 files.
the only thing i am doing different is that i am ripping a ntsc movie.
what have i missed or not doing.
thanks
dave king
I assume you have a software dvd player installed, so you have a registered ac3dec directshow filter too. So you may try to set direct show multi media file reader to higher priority. However, TMPG sometimes have problems with compressed audio, so I suggest to convert the .ac3 to .wav. Besweet uses azid to decode and ssrc to downsample (if you need it).[/url]
Can not open any file in TMPGEnc 4
By Soixante in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 08:56 -
MuxMan 0.16.7 will not open AC3 audio file.
By Nagashi in forum AudioReplies: 9Last Post: 27th Jul 2010, 10:29 -
can't open file in TMPGEnc
By windranger in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2009, 09:25 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
Can TMPGEnc open AC3 audio?
By TheEvilHammer in forum Video ConversionReplies: 14Last Post: 17th Mar 2008, 15:32
