  1. Started to create my first DVD last night. Recorded a couple clips using ATI at 740x480 at 8m. Fired up VP5 and started dragging the clips into the program. Each clip when dragged in gave me a message with the mux rate in red. It appeared to be higher than the 8m that I recorded at. After I placed everything like I wanted it I told it to record. It started a conversion. Watched the red light for the hard drive buzzing away. Then it started somthing called separation. That's where the trouble begins and ends. It gets all the way to 100% and it stays there forever. Did this for 2 1/2 hours. Did find a couple of VP5 files in the windows temp directory with the correct names on them. Anybody have any ideas or solutions? By the way I have made many VCD and SVCD disks with this program. Got the same inital mux rate message, but it always went through and made the CD.
    Thanks,
    Little John
  2. P.S.
    I also tried lowering the res to 352x480 along with the bit rate to 7m and had the same problem.
    Thanks,
    Little John
