Hello
Title four in my VIDEO_TS folder has audio that is out of sync for about 15 mins.My question is
How can I put the audio in my VTS_04_1.VOB file back in sync, and slot it back into place without having to re-encode the entire DVD again?![]()
Demux (PGCDemux)
Break the audio into 3 pieces - before the problem, the problem part, after the problem (HeadAC3he)
Correct the delay of the middle problem part (DelayCut)
Reauthor, adding back the 3 audio pieces, including the fixed middle part (Muxman)
Replace the fixed DVD back into the original DVD (VobBlanker)
The final part of the audio will be probably be thrown off after you fix the middle part. If, after reauthoring you find that to be true, you may have to delay the audio of the 3rd part by the opposite amount as what you delayed the 2nd part, as well and reauthor yet again.
PAL .VOB to NTSC .VOB Sound out of Sync
By zaque2004 in forum ffmpegX general discussionReplies: 4Last Post: 15th May 2009, 08:59 -
VOB sync problems when selecting within a file
By Fishcat in forum Newbie / General discussionsReplies: 6Last Post: 23rd Feb 2009, 12:50 -
Need to merge several VOB files, then shrink the final VOB file & burn
By pmolson in forum Video ConversionReplies: 7Last Post: 21st Oct 2008, 19:10 -
vob file out of sync when extention changed to avi
By sigmma in forum EditingReplies: 7Last Post: 26th Oct 2007, 08:11 -
How is done the sync between audio and video in a MPEG2-VOB file stream
By rmanal in forum EditingReplies: 0Last Post: 22nd Aug 2007, 09:33
