I converted an mkv to .vob with SUPER.
Then I converted the .vob to .avi with VirtualDub because there where subtitles to include.
But then ( I used 1st pass and 2nd pass conversion ) the output movie doesn't run
smoothly, it's kinda shocky if you know what I mean...
Until I converted the movie to .avi, the movie did run smoothly!
Am I doing something wrong in VirtualDub?
Results 1 to 10 of 10
Kate: What's the big thing that happens every Monday at one o'clock?
Tom: The dog outside the pub scratches itself...?
Kate: The plane from Broken Hill arrives! -
What codec did you use during the conversion to AVI? If you used uncompressed AVI theproblem is most likely your hard drive not keeping up with the speed of the video.
BTW: I am not familiar with SUPER but can't you save the result as an AVI from there? You are loosing a lot of quality by first converting to mpeg2 (VOB) and then to AVI. It would be better to first use SUPER to a lossless codec like Lagarith or HuffYUV and then add the subs in VirtualDub, saving to whatever codec you want as end result (most likely DivX or XviD).In the beginning the Universe was created. This has made a lot of people very angry and been widely regarded as a bad move. -
I use the Xvid MPEG-4 Codec.
If I use SUPER to convert the mkv to avi,
will the quality loss be less then if I first convert
to MPEG-2?Kate: What's the big thing that happens every Monday at one o'clock?
Best would be to avoid Super alltogether. I'm sure there are other routes from MKV to AVI - Have you tried any of these?
https://www.videohelp.com/guides?searchtext=&tools=&madeby=&formatconversionselect=MKV+...or+List+Guides
/Mats -
Yep, Virtualdub won't convert my mkv ( something with direct stream copy but I can't choose any other option! )
I've also tried riverpast.Kate: What's the big thing that happens every Monday at one o'clock?
Wow thanks! The quality is sooooo much better!
I have one question left, I can't figure out how to put the subtitles
in the file, permanent I mean and not selectable...Kate: What's the big thing that happens every Monday at one o'clock?
If you don't have a special reason, keeping external subtitles (like in .srt format) is always to be preferred, as adding permamnet requires reencoding, and if they aren't made permanent when going to AVI in the first place - well, there's quality loss down that road...
/Mats -
I got it working!
Thanx for all the help and I have one last question,
what is the music on the background of AllToAvi?
It sounds so familiar and I can't figure out where
it's from!Kate: What's the big thing that happens every Monday at one o'clock?
H264 conversion problem Virtualdub
By Shadowofthedarkgod in forum Video ConversionReplies: 11Last Post: 8th Nov 2015, 13:42 -
[solved]3d side-by-side capture and conversion to anaglyph using VirtualDub
By jumpjack in forum Capturing and VCRReplies: 21Last Post: 13th Apr 2011, 19:23 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
VirtualDub Mod Conversion from DVD, no audio in FCE
By Jralph in forum Video ConversionReplies: 2Last Post: 29th Apr 2009, 10:09 -
Conversion usiing VirtualDub - 720 X 560 videos into 640 X 360 videos
By candyman9999 in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 22:13
