    Jun 2005
    USA
    This is probably a dumb question, but is there a way to write a script for VirtualDub to do your encoding? I mean I crop out clips from TV shows and it's always the same null transform filter to crop out the edges, the same resize, the same compression, and the same bit rate. Is there any way to automate this tedious task with VirtualDub or any other program? Thanks!
    Apr 2004
    Miskatonic U
    Use avisynth instead. It is designed to do exactly what you are asking, and a lot more. You can even use many virtualdub filters in avisynth.
    Read my blog here.
    Sep 2007
    Europe
    "Save process settings" on the vdub files menu should do that. This also saves the used plugin filters.
    Or do you mean some kind of job processing? Vdub has also a job control on the files menu.
    Chris.
