Using Adobe Premiere CS3
How do I change the capture file format? It's currently mpeg. I want to change it to avi. I looked all threw the menu's. Strange that it defaults to mpeg. In Adobe Premiere 7 it defaulted to avi.
Results 1 to 16 of 16
Oh sorry, capturing from a Cannon video camera.
Well, it's the same video card/drivers I used with Adobe Premiere 7, and it let me capture to avi.
There was a place to change the capture format that I saw, but it was disabled (grayed out) -
WinDV is small, dedicated, and does only one thing, and does it well. It uses few system resources as well. If you really only have 128 mb ram then you will need small programs to get a clean transfer. I hope that is actually a typo, or Premiere is going to run like a three-legged dog.
Read my blog here.
This is an HDV cam though... still ok? The video was recorded in HDV as well
Since when can Premiere capture with MPEG?
OK becoming clear now.
HDV is MPeg2 and normally is captured and edited in native HDV project format or converted to a digital intermediate.
Why avi? What are your goals? -
My goal is to rip in the highest quality possible I suppose. AVI is raw isn't it? Just a container. Mpeg-2 has compression right? I suppose the quality difference between the 2 is minimal right? That's what i've read anyway. This isn't a professional project, so i suppose mpeg will suffice. This is ultimately going to be a DVD so maybe staying with mpeg is better since DVD is mpeg. What do you think?
You get no greater quality from decompressing MPeg2. Actually you may loose quality by fully decompressing and recoding from base video. Regardless, to get from HDV to standard deininition DVD you are reducing quality greatly.Originally Posted by djbryson
What kind of editing do you plan? -
Ok, didn't realize HDV was mpeg2, so it's better to leave it as mpeg. The less conversion/compression the better to maintain quality. Just doing some basic editing. Chops, sub titles, simple transitions, no crazy effects.
In native HDV project mode, Premiere CS3 will only decode GOPs that are affected by cuts or transitions. Downsizing to DVD 720x480 will degrade all GOPs. Best to retain an HDV copy for the future.
http://www.kiva.org/about -
I also want to capture to AVI. Looks like WinDV might be good. You should understand that the AVI file is just a container and in this case it is containing MPEG. Also note that the timecode from the tape can only be stored in the AVI file. I'm still researching, but it appears the tape timecode can not be stored in MPEG files. Suprisingly, Premiere discards the tape timecode (I'm using Premiere Pro V2). The timecode is usefull if you ever need to know the date/time of the scenes or split the scenes into clips based on camera start/stop to aid in editing. Another great tool for DV timecode usage is DVDate.
Change video to another format?
By Venessa@123 in forum Newbie / General discussionsReplies: 5Last Post: 10th Aug 2011, 02:10 -
How to change NTSC to PAL in adobe premiere elements 7
By jarko in forum Newbie / General discussionsReplies: 2Last Post: 26th Jul 2009, 20:28 -
Change speed on a clip in Premiere?
By FredAstair in forum EditingReplies: 5Last Post: 18th Jan 2009, 13:08 -
rip AC3 track without format change
By shun in forum DVD RippingReplies: 2Last Post: 9th Feb 2008, 03:01 -
Can I Change Format???
By jmarkt in forum Authoring (DVD)Replies: 2Last Post: 30th Jul 2007, 15:48
