Hi, it's my first time here in the forums....
Well I just want to ask if there's any way to remove menu buttons in a motion menu without converting it to a still image....
Hoping for your reply.....thanx a lot!!!
It depends on how the menu has been made. Some only use sub-pictures for the menu items, in which case MenuEdit, DVD Remake Pro or PGCEdit should be able to remove the options. However many actually have the options embedded in the video (I know I make mine this way) and use the sub-pictures only for indicating the user choice. This makes it much more complex.
Read my blog here.
You can re-encode it with overlays (e.g. using AviSynth) or do so by making a fake project in TDA3 (with so many chapters for any input file) with original menu as motion background and 'image objects' from 'advanced' (button below menu edit page) to hide old buttons and make new text buttons over those objects.
Hi,
Thanx for the help, Ive been successful in removing unwanted menu buttons in the motion menu by using pgcedit and voblanker. Well, how bout the menu button text? Though the menu buttons are removed, menu text are still visible, Is there any way for me remove those unwanted menu text in the motion menu.
I'm still a noob, but I'm eager to learn.....hope u guyz could help!!
Thanx -
I do it quite often myself, hide or remove something from a motion menu that I don't want to have in there anymore. I do it as Alex_ander described, using an AviSynth script with an overlay added to cover up what I want removed. My menu editing guide explains the necessary steps involved - everything that is, except how to reencode the menu:
https://forum.videohelp.com/topic313743.html#1606732
If gallardo isn't an experienced AviSynth user and encoder, then it might be better if he stills the menu(s) using VobBlanker or MenuShrink and extracts a BMP for editing, which makes the whole process much easier.
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Editing and replacing a motion menu problem
By kpic in forum Authoring (DVD)Replies: 4Last Post: 5th Aug 2010, 17:11 -
Problems when creating a mix with motion menu and static menu
By ihmcjacky in forum Authoring (DVD)Replies: 59Last Post: 15th May 2008, 11:01 -
Motion menu thumbs in DVD Workshop 2
By milway in forum Authoring (DVD)Replies: 7Last Post: 3rd May 2008, 07:12 -
Motion Menu on dvd lab pro 2
By djakaburo in forum Authoring (DVD)Replies: 1Last Post: 12th Apr 2008, 12:03
