Now my old PC had a standard 15 pin vga hookup and so does my monitor and flat panel tv. So I had no problem hooking up my flat panel to view my PC.
My new computer has I guess it would be a 28 pin dvi hookup. I have an adapter to go from dvi to vga and my pc hooks up to my Samsung 19" monitor with no problem. But when I hook that up to my TV, my TV displays "no signal".
HELP!!!!
I guess you have tried different resolutions and hz?
You may also need the TV to be turned ON before you power up the PC.
Google is your Friend -
The TV will only accept a limited set of resolutions and only 60Hz refresh.
Check your TV manual.
Good guesses would be 1024x768 or 1366x768Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
eSATA hookup
By yogart in forum Newbie / General discussionsReplies: 12Last Post: 23rd Jan 2010, 18:58 -
Vizio flat panel aspect ratio problem
By consumerx in forum DVD & Blu-ray WritersReplies: 9Last Post: 2nd Jan 2009, 05:58 -
Investing in 40+ inch Flat Panel TV...Trying to gather information.
By chewie8008 in forum Off topicReplies: 26Last Post: 20th Jul 2008, 18:35 -
PC to LCD - How to hookup?
By Captain Satellite in forum DVB / IPTVReplies: 42Last Post: 13th Nov 2007, 10:36 -
New DirecTV (or maybe DN) Hookup - Questions
By BQuicksilver in forum DVB / IPTVReplies: 1Last Post: 18th May 2007, 00:02
