what is a digital stream ?
Results 1 to 12 of 12
I guess you mean http://en.wikipedia.org/wiki/Digital_television and then you can use capture card that records the digital stream instead...
Yes, with a digital only or combo digital/analog tuner.
Digital tuning comes in three flavors...
ATSC for over the air (OTA) broadcasts
QAM for cable digital channel reception (ATSC tuners don't function for cable)
DVB for certain satellite dish reception -
What do you want to do? What is your stream source?Originally Posted by MosThaTeD
Over the air? First find your "digital" stations at http://www.antennaweb.org/aw/welcome.aspx and follow their suggestions for an antenna. Then buy an ATSC digital tv tuner for your PC.
http://www.newegg.com/ProductSort/SubCategory.asp?Subcategory=47&DEPA=0&CMP=KNC-Google...ards-_-NA-_-NA
FAQ
http://www.avsforum.com/avs-vb/showthread.php?t=611957 -
i want to record tv shows for the net , i have digitalcable from time warner cable , and thinking of buying the ATI TV WONDER 650
"tv shows for the net" ?Originally Posted by MosThaTeD
The 650 has QAM capability and in theory can capture your local TV off Time Warner cable.
This may prove difficult because neither ATI nor TimeWarner are very user friendly. -
A better method of recording HD TV is to record directly from a cable box via firewire to your PC. This does not require the use of any TV card in the PC but it does require you to have a digital cable box. Note that recording of encrypted shows (this usually means movie channels like HBO and pay per view events) will NOT work with this method. But you can record, say, CSI from CBS with this method.
http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=403695 -
thanks for the link
do u think it will work with a timewarner dvr ?
How to stretch longer audio stream to a shorter video stream ?
By ralf07 in forum AudioReplies: 9Last Post: 31st Aug 2011, 22:42 -
Problem converting from MPEG Program Stream to Transport Stream
By vivajam in forum Newbie / General discussionsReplies: 5Last Post: 24th Jan 2011, 04:40 -
Help with ripping movies where Dolby Digital 5.1 audio stream is not 0x80
By Twerthi in forum Newbie / General discussionsReplies: 5Last Post: 20th Jun 2009, 00:18 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 03:27 -
Digital Rapids Stream - Deck Control?
By Nocturnaloner in forum Capturing and VCRReplies: 0Last Post: 16th Dec 2007, 22:47
