ok, so i put all the video input files in, put all the menu info in, and when i click Generate DVD FAVC will either close completely or give me one of 2 error messages. the first is titled "FAVC 1.04 - Mr_Odwin" and it says "Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
An attempt was made to load a program with an incorrect format.
(Exception from HRESULT: 0x8007000B)."
the error box has a Details, Continue, and Quit button.
the 2nd error is titled "FAVC.exe - Bad Image" and says "The application or DLL E:\Program Files\FAVC\MediaInfo\MediaInfo.DLL is not a valid Windows image. Please check this against your installation diskette."
i don't know what to do since you dont really install FAVC, you just unzip and run it. i already installed the latest Avisynth and .NET framework.
Error messages burning data DVD using Nero version 6
By craigsb in forum ComputerReplies: 6Last Post: 27th Oct 2011, 09:12 -
Kmplayer error after closing
By alintatoc in forum Newbie / General discussionsReplies: 0Last Post: 28th Oct 2010, 13:20 -
No Mouse Double Click Button in Windows 7 ?
By wulf109 in forum ComputerReplies: 2Last Post: 22nd May 2009, 12:59 -
TMPEGENC keeps closing itself because of an error
By Akhet in forum Newbie / General discussionsReplies: 1Last Post: 14th Oct 2007, 00:38 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
