So I just installed FFMPEGX on my MBP, I loaded the binaries, got the (old) stable build of the reallib.zip file, unzipped it, put it in application support.
When I give the program a rmvb file, it just freezes. This happens if I drag and drop to the window, drag to the icon, or click the open button.
I've tried it with the unzipped folder, the zipped file (with .zip extension removed by terminal) and with out the reallib in there at all.
I got 10.4.10, using ver 0.0.9x
Is this an intel thing? A ffmpegX thing? A dumb user thing?
EDIT: Further searching on the forum found this: https://forum.videohelp.com/topic322562.html#1659446
Which solved the problem.
I'm leaving this post undeleted to help as a pointer. Is it possible to add the info in that thread to some non moving FAQ for FFMPEGX?
Results 1 to 1 of 1
RMVB File Question
By THUGGY1111 in forum Video ConversionReplies: 3Last Post: 17th May 2011, 20:33 -
Repairing A RMVB File
By niteghost in forum Newbie / General discussionsReplies: 1Last Post: 12th Jan 2009, 20:15 -
There is no audio on .rmvb file during playback
By Aayanna24 in forum AudioReplies: 2Last Post: 23rd Sep 2007, 18:40 -
Extracting audio from RMVB file.
By capman21 in forum Newbie / General discussionsReplies: 4Last Post: 24th Jul 2007, 02:00 -
RMVB file???
By BigCol in forum Authoring (DVD)Replies: 1Last Post: 13th Jul 2007, 17:23
