I'm getting a minimal blurness about every 10-15 seconds. The blurness started ever since I hooked my Toshiba HD-A20 to my Onkyo TXSR-605 and then my Toshiba 47" 1080P LCD with HDMI. I called Toshiba and Onkyo and they didnt know any cause. Does anyone have any solutions?
Results 1 to 14 of 14
Try connecting it directly to the TV. That will help narrow down the posibilities.
Google is your Friend -
If I do that, I wont get the benefit of Dolby-true HD and uncompressed 5.1....C'mon man, I knew that!
You don't need to use it that way permanently. If you connect it directly and the problem continues, then it is likely the A20. If you connect it directly and the problem stops, it's the Onkyo. Without doing any troubleshooting, you won't find out the cause of the problem. Either way, this is likely a hardware issue that you won't be able to fix on your own. You need to know what isn't working so you can have it replaced/fixed.
It seems like it's getting worse. It appears to be motion blurness. It occurred ever since I performed the recent update from Toshiba. Any ideas?
I haven't heard of any other blurriness issues. You could return the A20 or take it to a repair center.
Before doing that, I would perform some troubleshooting. Bypass the 605 (it has had several issues) and see if the problem continues. It it doesn't, your 605 is the problem. If it's the same, take the A20 to a friends or back to the store and try it on another TV. If the problem continues, the A20 is faulty. If it doesn't, then your TV is at fault.Google is your Friend -
What issues have you heard of? I called Onkyo and they claim they havent noticed any issue regarding my situation. They suggested for me to reset receiver. I'll do that when I get home.
There is a very long thread over at avsforums covering the 605 issues.
The problem (at least from what you've posted here so far) is that anything we say is just guessing. You/we don't even know what piece of hardware is actually causing the problem. At this point it could be any of the three.Google is your Friend -
I did some test and discovered that the Toshiba HD-dvd player may have the issue. I hooked up my Sony dvd player to my Onkyo and did not see the motion blurness. I also hooked the Toshiba directly to my TV and still saw a little blurness. It's strange because when I play HD discs in the Toshiba, I really dont see the blurness at all....STRANGE!
So you are only seeing the bluriness when playing SD discs in the Toshiba?
Practically yes. To be honest, most of the SD discs have motion blurness, but not all.
The Toshiba drives are known for their upconversion abilities, and they are supposed to be one of the best players at upconversion. With that said, have you tried disabling the upconversion (or vice versa)?
No not yet, but why do I wanna select 480P or 720P when the whole purpose of playing SD discs in the Toshiba is to take advantage of the upconversion?
I'm just assuming that what you may be seeing is a result of the conversion. If turning it off corrects the issue, then you will at least know what is causing the problem and you will have more information to provide Toshiba.
And the whole point of having a HD player is to play HD discs. Upconversion is just an optional benefit, which in this case doesn't seem to be a benefit.
The main problem know will be if the problem can be reproduced on another TV.Google is your Friend
Toshiba Sat. A200-AH6 laptop DVD drive cannot read DVD DL discs
By MeekloBraca in forum DVD & Blu-ray WritersReplies: 11Last Post: 9th Dec 2009, 03:27 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
Got new dvd recorder, Toshiba vs Magnavox
By heman28 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 5th Mar 2008, 10:24 -
Toshiba A2 and DVD-R disks
By Prot in forum DVD & Blu-ray PlayersReplies: 4Last Post: 29th Jul 2007, 19:28 -
Toshiba DVD recorders
By DVWannaB in forum DVD & Blu-ray RecordersReplies: 3Last Post: 22nd Jun 2007, 16:28
