Hi all, i am using nero vision to convert avi's to dvd and adding a menu with no problem but i decided to try to add some menu music and these ones will play ok in a pc but not in dvd players. Nothing comes up in dvd player just blank screen - redid the conversion removing the music and it worked fine.
i used an mp3 but should they be in another format before adding to the menu in nero?
cheers in advance for any help
smudge
Valid DVD audio is (basically) mp2 (aka mpa), AC3 and LPCM (wav). All has to be 48 kHz. If Nero let you add MP3 as menu audio, it ought to have converted it to a proper DVD audio format, but with Nero, you never know. Try feeding it a DVD compliant audio to see if that makes any difference.
/Mats -
thanks mate, converted them to wav format and work fine now, guess nero had problems with comversion
cheers, smudge
How to delete a menu & create/insert a new one with Nero Vision Xtra?
By snowseals in forum Authoring (DVD)Replies: 22Last Post: 26th Aug 2011, 23:03 -
Adding a menu to a DVD of music videos with no menu
By vtrop in forum Authoring (DVD)Replies: 1Last Post: 25th Feb 2009, 09:07 -
Nero Vision 5 menu audio help?
By sls-sls in forum Authoring (DVD)Replies: 1Last Post: 31st Oct 2007, 12:26 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 11:10 -
Nero Vision 5
By marioval in forum Authoring (DVD)Replies: 0Last Post: 11th Oct 2007, 13:45
