I just bought a Plextor PX-810SA to replace my old Plextor 716A. Now I'm having an issue with buring DVD9 discs on PX-810SA and playing them in my DVD player (XBox360). If I burn a DVD9 disc at any speed then try to
play it in my dvd player it won't read the disc, However if I used my 716A(I have used for years) with the same media/speed it works fine. So far I have tried Sony and Verbatim DVD9 I might try some HP just to see if the media is an issue but I'm not sure. Is their anything else I could try?
Folks replacing old Plextor's for new ones should note that Plextor no longer makes drives, just re-badges. You probably have a Pioneer drive.
stick to VERBATIM DL MEDIA. any other brand of DUAL LAYER MEDIA will only result in burning COASTERS.
My Plextor 755 gets pretty decent results with Ritek D01 @ 4x. Not as good as Verbatim MKM001s, but still quite usable. Scanned with a BenQ.
Plextor PX-AV200U or ???
By wtsinnc in forum Capturing and VCRReplies: 4Last Post: 11th Nov 2008, 13:46 -
Advice on a new audio/video system(I need advice and direction)
By hellfire45 in forum Newbie / General discussionsReplies: 1Last Post: 15th May 2008, 00:20 -
Looking For Advice. I'm hoping to get some advice about a DVD burner
By wtsinnc in forum DVD & Blu-ray WritersReplies: 5Last Post: 4th Dec 2007, 23:39 -
Plextor PX-760A
By SCDVD in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Aug 2007, 01:24 -
Plextor M402U
By LeFreak in forum Capturing and VCRReplies: 5Last Post: 6th May 2007, 21:33
