I have Premiere CS3. On all my stations but 3 I cannot export a video to a DVD that will play in a DVD player. It will play in the media player and the DVD software on a computer, but not on a stand alone player. Any suggestons why this is happening?
Are you authoring and burning with premiere cs3(if that is even possible)? You should have a VIDEO_TS folder with vob,ifo,bups on the DVD.
i am editing with Premiere and when you export the video it automically exports to encore now. Takes you through the buring process without any options unless you choose to create a menu which we do not.
Okey, Adobe Encore should make a compatible dvd-video. Have you just tried it on one dvd player? Maybe try different dvd media, dvd-r or dvd+r or another brand, see www.nomorecoasters.com and www.videohelp.com/dvdmedia .
I have tried that but will try again. But why would it the burning porcess work on one station and not the others? The software was burnt to an image and installed on all 20 of my stations. they should be identical.
Using same media also? It could still be the media or maybe the writers.
Sending video from my computer to TV?
By NeWcS in forum ComputerReplies: 26Last Post: 16th Jul 2011, 10:16 -
Outlook not sending emails
By Squid_uk in forum ComputerReplies: 3Last Post: 8th Mar 2010, 14:16 -
Sending video to firewire to component.
By spec09 in forum Video Streaming DownloadingReplies: 1Last Post: 16th Oct 2009, 07:09 -
Will sending video from my TV through my vcr/dvd player get rid of lines?
By Darkstraw in forum Newbie / General discussionsReplies: 7Last Post: 14th Aug 2008, 23:47 -
sending dvd to europe - PAL questions
By cduval04 in forum Authoring (DVD)Replies: 6Last Post: 2nd Jun 2008, 20:18
