as the title says . The cable wire in my home is plugged into my analog TV through RF Connector , but can a S-video connector be connected to the same wire instead of RF Connector to connect into TV Tuner ?
no you cant connect this way.
if you have a scart socket on the tv set you can buy an adaptor that will accept an s video connector in to the scart socket.
http://www.svideo.com/svideoscart.html
http://www.svideo.com/compaq1700.html
http://www.weethet.nl/english/video_connect_pc2tv.php -
I do not know if this is what you want, but check this site.
http://www.svideo.com/svideocoax.html -
ok , i read the pages .
Wat i need to know is if there is a converter which does opposite of that in the above links i.e. RF to S-Video . -
I do not know what are you trying to do, but any new TV cable converter will have S-Video output.
Check this also:
http://www.unbeatablesale.com/dbm61151.html?utm_source=nextag4&utm_medium=cpc&utm_term...=07-34855701-2 -
That's an RF modulator - i.e., it converts the switched S-video etc to RF for use with standard televisions.
A challenge for the OP is (I assume) that whatever unit is found needs to be PAL, too.
Also, the need for S-video can be questioned. The demodulated signal is composite so any cable box with S-video output will be generating it from the composite signal. If the goal is to connect the signal to a capture card that has both composite and S-video input, it can do the conversion instead of the cable box. This may widen the number of available options. -
Yes, a cable box.Originally Posted by wolf2009
Explain more clearly what you are trying to do.
RF cable is a 500MHz to 1GHz spectrum which requires a tuner of some kind to isolate one channel from ~100 (analog) to ~500 (digital) channels available on the RF cable. S-Video would be the output after the tuner tunes a channel.
Speaker wire to RCA? cable needed...
By flamy in forum AudioReplies: 12Last Post: 24th Dec 2010, 13:05 -
Picture Quality on a HDTV connected to co-ax cable
By grk417 in forum DVB / IPTVReplies: 3Last Post: 1st Feb 2010, 00:23 -
Hi8 player to DVD recorder - S Video cable, RCA or Fire Wire?
By Dixie Paul in forum Newbie / General discussionsReplies: 10Last Post: 5th Jan 2010, 09:56 -
By Dixie Paul in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Jan 2010, 12:33 -
can usb replace fire wire cable??
By Berghof in forum Newbie / General discussionsReplies: 2Last Post: 8th Dec 2007, 23:48
