When I am finished converting an avi/divx to dvd and the file has burnt I always get 3 error reports. The last 3 are attached.
The converting and burning are always successful. Other than that I have no problem with this version. I was getting the same with the last version also.
xp sp2
Pent 4 3.2ghz
1 gb ram
200 gb wd
svcd2dvd.txt
This post and the two following:
https://forum.videohelp.com/topic337498.html#1761098Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Which burning method are you using?
I suspect that could be it then. ImgBurn is the preferred method, but if the DVDs are fine then i would just ignore these messages.
SVCD2DVD Error when encoding menu??
By gsmb in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 23rd Feb 2011, 13:44 -
Error on Startup SVCD2DVD 2.5
By jenevans33 in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 04:05 -
Problem.. DGIndex reports "motion code error" :cry:
By _migz_ in forum Video ConversionReplies: 2Last Post: 27th Nov 2007, 06:09 -
svcd2dvd error urgent request
By dvds2u in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 10th May 2007, 09:22
