Recently purchased a DVD recorder. Model number is: DVDR3475
TV: Toshiba 35AF44
Sat. Box: Dish 322 http://www.dishnetwork.com/downloads/pdf/product_brochures/dish_322.pdf
Problem is that no matter how I connect the wires, I cannot seem to get the DVD recorder to record TV. It doesn't seem to 'see' the sat. coming in. It comes in on channel 3, but I cannot get everything configured so the end result is recording sat. tv.
Can anyone help with this?
	I don't want to sound condesending but did you set it up read the sattelite as a tuner source? Usually in the setup menu somewhere you have to set it up to read either from an antenna, cable or satellite.
 Also - are you trying to record movie channels like Showtime or HBO? Those are almost certainly encrypted and won't let you record them. Just an observation.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	Thank you for the prompt reply. I did set it as such, Or so I thought I did, And we are trying to record anything. Fox mainly.
	Try a different approach. Setup the video output from your sat and go to the input on the dvd recorder. Then change to the video input on your dvd recorder. You should be able to record that way. The only downside is with this method you can't change the channel through the dvd recorder, only the sat box.
 Good luck.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	Would it help if I currently snapped a photo of all my hook ups? I am currently new to all of this, and its extremely confusing. Right now, its as if the DVD recorder never sees the Sat. box, And I get asked about E1 and E2 inputs.
	That would probably help us point you in the right direction. If I'm not online after you post somebody else could step in.
 Chances are e1 and e2 are simply reffering to two input slots you have available on your dvd recorder. Each one will be labeled properly. Which ever one you plug into set your dvd recorder to that input. That should pick it up then.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
	The Dish 322 is a two tuner unit. You can only record a channel that the dish is tuned to
 This would be for two sources as two TV’s , another TV a Recorder or both os you could watch one ch and record another.
 It should have two separate outputs (RCA) jacks
 One could go direct to the TV, the other to the recorder input, than from the recorder output to a TV input
 This is one way and could require changing input sources to the TV.
 I believe the Toshiba TV is a CRT that has multiple inputs and they should be RCA jacks
 There are a number of ways that it could be connected
 I would suggest that you check the TV manual, DVD manual and the Dish manual They should guide you to a proper connection
 I would use any RCA jacks for connection to the TV and Recorder over the ch 3 or 4 option. If possible
  connecting sattelite reciever box, tv, and dvd recorder.By steve6 in forum MediaReplies: 4Last Post: 19th Feb 2011, 14:56
  DVD Recorder & Cable BoxBy pepegot1 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Oct 2010, 18:43
  Dazzle DVD Recorder on old Win2k box??By ramsejp in forum Capturing and VCRReplies: 6Last Post: 8th Jul 2008, 14:49
  Hardware for Vista MCE and Sat BoxBy RubicksCube13 in forum Capturing and VCRReplies: 0Last Post: 26th Dec 2007, 19:37
  dvd recorder and dvr box setup helpBy backdrop001 in forum Newbie / General discussionsReplies: 3Last Post: 5th Dec 2007, 11:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
