ok i was getting into recording shows but my capture card messes up when i open the program for it
when i open it up it shakes up my screen and freezes and when i use iuVCR does the same thing but if i just press record it records but when i open the file with windows media player it plays but the audio doesn't match with the video and the video plays super fast
i have a Hauppauge WinTV-GO-FM any help plz
and whats a really good capture card that records hd ..
Open what up? The hauppuage wintv capture tool? I had an hauppauge wintv some years ago and didn't have problem with the included software. Try download latest software and drivers from hauppauge site.
And you wont find many hd capture cards. If you want to capture from hdtv then get a digital capture card/device that records the digital stream instead, https://www.videohelp.com/capturecards?CaptureCard=&atsc=1&hdtv=1&searchconnection=Any&...&Search=Search -
when i open WinTV2000 i messes up
i already downloaded the drivers from the site same thing happens
what do u recommend me to get to record hdtv?
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
