I have the latest registered version of SVCD2DVD. I get no errors when converting but when I playback the DVD on my DVD player, I get a clipping sound in the last 2-3 chapters. I've tried 3 different avi files with the same result. I've also tried different settings with no success. Also, the sound is OK when I play it on my computer and my DVD player plays other DVDs with no problems. I didn't have this problem with SVCD2DVD 2.1.
Here is a log:
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.3300.0
Executable: C:\Program Files\BadgerIT\SVCD2DVD v2.5\SVCD2DVD.exe
Executable size: 2,55 MB
Executable size in bytes: 2682963
Executable CreationTime: 25.09.2007 17:40:06
Executable LastWriteTime: 30.09.2007 21:48:59
Executable LastAccessTime: 02.11.2007 19:52:11
************************* Operating System *************************
Operating System: Microsoft Windows XP Professional
Service Pack: Service Pack 2
Version : 5.1.2600
Windows Directory : C:\WINDOWS
OSLanguage: 1055
CodeSet: 1254
CountryCode: 90
Local: 041f
Total Physical Memory: 1,99 GB
Free Physical Memory: 1,42 GB
Total Virtual Memory: 1,99 GB
Free Virtual Memory: 1,95 GB
***************************** Computer *****************************
Computer Manufacturer Name: System manufacturer
Computer Model: P5KC
System Type: X86-based PC
Computer Name: TURANCANSU
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 2
User Name: TURANCANSU\Turan Cansu
***************************** Processor ****************************
Manufacturer: GenuineIntel
Processor: Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz
Description: x86 Family 6 Model 15 Stepping 11
CPU Speed: 2,671GHz
CPU FSB: 333MHz
L2 Cache Size: 4,00 KB
CPU Speed: 2,671GHz
CPU FSB: 333MHz
21:55:45: Logical CPUs: 2
***************************** Time Zone ****************************
Time Zone:
****************************** VIDEO *******************************
Name: Radeon X1950 Pro (Omega 3.8.413)
Processor: ATI Radeon Graphics Processor (0x7280)
Mode: 1440 x 900 x 4294967296 renkler
Video Ram: 512 MB
Status: OK
Name: Radeon X1950 Pro Secondary (Omega 3.8.413)
Processor: ATI Radeon Graphics Processor (0x72A0)
Mode:
Video Ram: 512 MB
Status: OK
****************************** Drives *******************************
DeviceID: C:
FileSystem: NTFS
FreeSpace: 30,4 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 74,6 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
<?xml version="1.0" encoding="utf-8"?>
<SVCD2DVD DateTime="02.11.2007 21:55:45" Filename="NONE">
<AssetSet>
<Asset ID="187b528c-c5b8-42d5-8f55-f0999604745e" Path="D:\Downloads" Filename="Fantastic.AVI" />
</AssetSet>
<DVDStructure>
<TitleSet Name="New Movie" PostCmd="" MenuButtonType="0">
<MenuButton X1="0" Y1="0" X2="226" Y2="53" FontFamily="Tahoma" FontSize="28" FontStyle="3">New Movie</MenuButton>
<Title Name="Fantastic.AVI" AssetID="187b528c-c5b8-42d5-8f55-f0999604745e" MplexOffset="0" />
</TitleSet>
<DVDMenu Normal="-1" Highlight="-65536" Active="-16711681" ShowPlayAllButton="False" DSOffsetWidth="1" DSOffsetHeight="1" DSColor="0" DSOnOff="True" BackgroundImagePath="C:\Program Files\BadgerIT\SVCD2DVD v2.5\default.jpg" AudioPath="" />
</DVDStructure>
<Settings>
<General InitialAssetFolder="" InitialDVDFolder="" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="True" UseDVDShrink="False" />
<Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="NTSC" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_4_3" />
<Process AudioEncoding="mpa" Chapters="Every 20 mins" SkipMPA48="False" SkipAC3="True" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" />
<Program BINExtraction="vcdxrip" VCDGearFIX="False" FastAudioEncode="True" />
<Burning BurningMethod="NONE" ImgBurnPath="" DVDDErase="True" DVDDClose="False" DVDDDontBurn="False" />
</Settings>
</SVCD2DVD>
Processing assets for DVD creation
=================== AV Details ===================
File Size: 1,34 GB
file=D:\\Downloads\\Fantastic.AVI
FormatName=avi
Num_Frames=155522
DurationInSecs=5189
Duration=01:26:29.2
VideoCodec=mpeg4
VideoFFSTNum=0
Width=640
Height=256
Standard=NTSC
BitRate=2233
AudioStreamCount=1
Audio1FFSTNum=1
Audio1StreamID=[0x1]
Audio1SampleRate=48000
Audio1Codec=ac3
Audio1BitRate=320
Audio1Channels=2
AVI2MPG: 6360kbs Full-D1
21:55:45: Looking for AVI PAR...
Leaving source audio alone.
Pass 1/1: Processing Fantastic.AVI
21:55:46: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
21:55:46: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
21:55:46: libavutil version: 49.1.0
21:55:46: libavcodec version: 51.27.0
21:55:46: libavformat version: 51.12.1
21:55:46: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
21:55:46: Seems stream 0 codec frame rate differs from container frame rate: 29.98 (65535/2186) -> 29.97 (2997/100)
21:55:46: Input #0, avi, from 'D:\Downloads\Fantastic.AVI':
21:55:46: Duration: 01:26:29.2, start: 0.000000, bitrate: 2233 kb/s
21:55:46: Stream #0.0: Video: mpeg4, yuv420p, 640x256, 29.97 fps(r)
21:55:46: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 320 kb/s
21:55:46: Output #0, dvd, to 'D:\Downloads\Fantastic_S2D.mpg':
21:55:46: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 6360 kb/s, 29.97 fps(c)
21:55:46: Stream mapping:
21:55:46: Stream #0.0 -> #0.0
21:55:46: Stream #0.1 -> #0.1
21:55:46: Press [q] to stop encoding
22:04:38: [dvd @ 0084E46C]packet too large, ignoring buffer limits to mux it
22:18:49: [dvd @ 0084E46C]packet too large, ignoring buffer limits to mux it
22:18:55: video:4026363kB audio:202705kB global headers:0kB muxing overhead 1.827070%
22:18:55: AVI2MPG: done.
22:18:57: Done: Processing assets for DVD creation
Authoring DVD Folders
22:18:57: Creating TitleSet # 1
22:18:57: SVCD2DVD: DVDfolders
Generating DVD folders please wait....
22:18:57: -->: DVDFolders creating VTS
22:18:57: -->: VTS 01
22:18:57:
DVD Folders: Processing D:\Downloads\Fantastic_S2D.mpg...
22:22:11:
22:23:45:
22:23:45: Finalising DVD...
22:23:46: SVCD2DVD: DVDfolders
22:23:46: -->: DVDFolders creating table of contents
22:23:46: scanning D:\Downloads\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
22:23:46: Finalising DVD...Done
22:23:46: Done: Authoring DVD Folders
Results 1 to 10 of 10
well the audio is not touched in this run due to your settings. Maybe change them to "AC3" but uncheck the skip for AC3 as follows:
I tried above but it left the audio alone again. (The audio of the asset was already AC3) The audio got worse.. Here is a log:
Title: 2.5
Version: 2.5.3300.0
Executable CreationTime: 25.09.2007 18:40:06
Executable LastWriteTime: 04.11.2007 18:45:55
Executable LastAccessTime: 05.11.2007 20:49:31
Version : 5.1.2600
OSLanguage: 1055
CodeSet: 1254
CountryCode: 90
Local: 041f
Free Physical Memory: 1,23 GB
CPU Speed: 2,671GHz
CPU FSB: 333MHz
CPU Speed: 2,671GHz
CPU FSB: 333MHz
22:51:26: Logical CPUs: 2
Time Zone:
Video Ram: 512 MB
Status: OK
Mode:
Video Ram: 512 MB
Status: OK
DeviceID: C:
FileSystem: NTFS
FreeSpace: 29,6 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 68,0 GB
<SVCD2DVD DateTime="05.11.2007 22:51:27" Filename="NONE">
<AssetSet>
<Asset ID="29a4024e-d216-46ac-a228-75f9f6c3740e" Path="D:\Downloads" Filename="Fantastic.AVI" />
</AssetSet>
<DVDStructure>
<Title Name="Fantastic.AVI" AssetID="29a4024e-d216-46ac-a228-75f9f6c3740e" MplexOffset="0" />
</TitleSet>
</DVDStructure>
<Settings>
<Process AudioEncoding="ac3" Chapters="Every 20 mins" SkipMPA48="False" SkipAC3="False" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" />
</Settings>
</SVCD2DVD>
File Size: 1,34 GB
FormatName=avi
Num_Frames=155522
DurationInSecs=5189
Duration=01:26:29.2
VideoCodec=mpeg4
VideoFFSTNum=0
Width=640
Height=256
Standard=NTSC
BitRate=2233
AudioStreamCount=1
Audio1FFSTNum=1
Audio1Codec=ac3
Audio1BitRate=320
Audio1Channels=2
AVI2MPG: 6768kbs Full-D1
22:51:27: Looking for AVI PAR...
22:51:28: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
22:51:28: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
22:51:28: libavutil version: 49.1.0
22:51:28: libavcodec version: 51.27.0
22:51:28: libavformat version: 51.12.1
22:51:28: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
22:51:28: Seems stream 0 codec frame rate differs from container frame rate: 29.98 (65535/2186) -> 29.97 (2997/100)
22:51:28: Input #0, avi, from 'D:\Downloads\Fantastic.AVI':
22:51:28: Duration: 01:26:29.2, start: 0.000000, bitrate: 2233 kb/s
22:51:28: Stream #0.0: Video: mpeg4, yuv420p, 640x256, 29.97 fps(r)
22:51:28: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 320 kb/s
22:51:28: Output #0, dvd, to 'D:\Downloads\Fantastic_S2D.mpg':
22:51:28: Stream #0.0: Video: mpeg2video, yuv420p, 720x480, q=1-31, 6768 kb/s, 29.97 fps(c)
22:51:28: Stream mapping:
22:51:28: Stream #0.0 -> #0.0
22:51:28: Stream #0.1 -> #0.1
22:51:28: Press [q] to stop encoding -
I also tested if there was a problem with my DVD writer. I burned the DVD with two different device. Both had the same problem.
Another log from another avi file used as an asset. This one also has the same problem:
Title: 2.5
Version: 2.5.3300.0
Executable LastAccessTime: 04.11.2007 20:42:36
Version : 5.1.2600
OSLanguage: 1055
CodeSet: 1254
CountryCode: 90
Local: 041f
Free Physical Memory: 1,30 GB
CPU Speed: 2,671GHz
CPU FSB: 333MHz
CPU Speed: 2,671GHz
CPU FSB: 333MHz
22:54:20: Logical CPUs: 2
Time Zone:
Video Ram: 512 MB
Status: OK
Mode:
Video Ram: 512 MB
Status: OK
DeviceID: C:
FileSystem: NTFS
FreeSpace: 29,5 GB
DeviceID: D:
FileSystem: NTFS
FreeSpace: 66,3 GB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 117 MB
<SVCD2DVD DateTime="04.11.2007 22:54:21" Filename="NONE">
<AssetSet>
<Asset ID="5f14ca21-0804-4503-ad8b-802c72bf1ad7" Path="C:\SVCD2DVD" Filename="Pathfinder.AVI" />
</AssetSet>
<DVDStructure>
<Title Name="Pathfinder.AVI" AssetID="5f14ca21-0804-4503-ad8b-802c72bf1ad7" MplexOffset="0" />
</TitleSet>
</DVDStructure>
<Settings>
<General InitialAssetFolder="" InitialDVDFolder="" OutputFolderName="SVCD2DVD_OUTPUT" InitialProjectFolder="" InitialMenuBackgroundFolder="" DeleteS2DFiles="True" UseDVDShrink="True" />
<Menu AudioEncoding="Custom_mpa" DefaultCustomAudioPath="" DefaultCustomImagePath="" TVStandard="PAL" FontFamily="Tahoma" FontSize="28" FontStyle="3" PlayAllText="Play All" Loop="True" ShowMenuStandardWarning="True" EncodeVideo2AudioDuration="False" MenuAspectRatio="AR_4_3" />
<Process AudioEncoding="ac3" Chapters="Every 10 mins" SkipMPA48="False" SkipAC3="False" PanSan="False" MergeTitles="False" UsePulldown="True" PAL2NTSC="False" AVI2PASS="False" AVI2HALFD1="FS" NoBframes_FullME="False" UseCustomMatrices="False" IntraMatrix="" NonIntraMatrix="" TVOverscanPixels="0" UseThreads="True" ForceWS="False" SafeMaxBitRate="False" />
</Settings>
</SVCD2DVD>
File Size: 700 MB
file=C:\\SVCD2DVD\\Pathfinder.AVI
FormatName=avi
Num_Frames=154158
DurationInSecs=6166
Duration=01:42:46.3
VideoCodec=mpeg4
VideoFFSTNum=0
Width=632
Height=256
Standard=PAL
BitRate=953
AudioStreamCount=1
Audio1FFSTNum=1
Audio1Codec=mp3
Audio1BitRate=112
Audio1Channels=2
AVI2MPG: 5440kbs Full-D1
22:54:21: Looking for AVI PAR...
Pass 1/1: Processing Pathfinder.AVI
22:54:22: FFmpeg version SVN-r7159, Copyright (c) 2000-2006 Fabrice Bellard, et al.
22:54:22: configuration: --enable-memalign-hack --disable-debug --enable-pthreads --enable-a52 --enable-gpl --enable-dts --enable-faad --enable-avisynth
22:54:22: libavutil version: 49.1.0
22:54:22: libavcodec version: 51.27.0
22:54:22: libavformat version: 51.12.1
22:54:22: built on Sep 13 2007 10:38:52, gcc: 4.3.0 20061204 (experimental)
22:54:22: Input #0, avi, from 'C:\SVCD2DVD\Pathfinder.AVI':
22:54:22: Duration: 01:42:46.3, start: 0.000000, bitrate: 953 kb/s
22:54:22: Stream #0.0: Video: mpeg4, yuv420p, 632x256, 25.00 fps(r)
22:54:22: Stream #0.1: Audio: mp3, 48000 Hz, stereo, 112 kb/s
22:54:22: Output #0, dvd, to 'C:\SVCD2DVD\Pathfinder_S2D.mpg':
22:54:22: Stream #0.0: Video: mpeg2video, yuv420p, 720x576, q=1-31, 5440 kb/s, 25.00 fps(c)
22:54:22: Stream #0.1: Audio: ac3, 48000 Hz, stereo, 448 kb/s
22:54:22: Stream mapping:
22:54:22: Stream #0.0 -> #0.0
22:54:22: Stream #0.1 -> #0.1
22:54:22: Press [q] to stop encoding
22:54:28: [dvd @ 0084E46C]buffer underflow
23:03:51: [dvd @ 0084E46C]buffer underflow
23:22:09: video:4092787kB audio:337220kB global headers:0kB muxing overhead 2.041325%
23:22:10: AVI2MPG: done.
23:22:11: Adding subtitle stream
23:22:11: SUP Error!
23:27:15: SupMuxer: Done.
23:27:15: Done: Processing assets for DVD creation
23:27:16: Creating TitleSet # 1
23:27:16: SVCD2DVD: DVDfolders
23:27:16: -->: DVDFolders creating VTS
23:27:16: -->: VTS 01
23:27:16:
DVD Folders: Processing C:\SVCD2DVD\Pathfinder_S2D.mpg...
23:31:55:
23:34:19:
23:34:19: Finalising DVD...
23:34:19: SVCD2DVD: DVDfolders
23:34:19: -->: DVDFolders creating table of contents
23:34:19: scanning C:\SVCD2DVD\SVCD2DVD_OUTPUT\VIDEO_TS/VTS_01_0.IFO
23:34:19: Finalising DVD...Done
23:34:19: Done: Authoring DVD Folders -
Do you mean with the source AVI or from your burnt DVD?Also, the sound is OK when I play it on my computer
Have you tried playing the S2D.MPG file to see if the sound problem is evident there?
What brand of DVD are you burning to?
What speed are you burning at?Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
I mean the burnt DVD plays fine on the computer. For some reason the s2d.mpg file won't play on my DVD player. It cannot identify the DVD and gives an error. I've tried different DVD brands, Maxwell, Philips and some nameless brand. The result is the same. I've also tried burning at x4 and x2.. No difference..
I am now thinking it might be my DVD player or my computer. SVCD2DVD 2.1 was installed on my laptop and it worked fine. (I'm now using SVCD2DVD 2.5 on my desktop computer) So, I will try 2.5 on my laptop tonight. Also, I watched a DivX movie on my DVD player tonight and realized some of the frequencies wouldn't sound. (Glass crash effects) This means my DVD player could be the problem. I will also check with another DVD player. -
Its seems to be either the burner or the media. I personally wouldn't use anything other than Verbatim or Taiyo Yuden discs. There should be a list of compatible media for your burner available from the manufacturer.
Dwight
- Herm Albright
OK.. I've tried burning the DVD with two different burners. I have one external and one internal DVD writer. Both had the sound problems. I've also tried Verbatim, TDK and Memorex discs, the same issue. I've also tried burning with different versions of Nero. I think it might have something to do with the DVD player. I still haven't tested the burnt DVD on a different player. However, the DVDs I created using version 2.1 works just fine on the same DVD player.
Maybe I should go back to 2.1? -
Drop me an email & I will send you 2.1.Originally Posted by zewzeqSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Thank you. E-mail sent.
I tested the DVD on another player today. No sound problems.. so this means my DVD player is the problem.
Originally Posted by ChrissyBoy
MKV2VOB sound problems
By DaxPG in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2010, 16:43 -
Problems with sound on 6ch
By pixiesoft in forum Authoring (Blu-ray)Replies: 3Last Post: 5th Apr 2010, 08:12 -
Sound problems
By maltipom in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2009, 14:37 -
sound problems
By deebo in forum Software PlayingReplies: 4Last Post: 9th Aug 2008, 15:43 -
avi2dvd sound problems
By justmenow55 in forum Video ConversionReplies: 5Last Post: 13th Aug 2007, 03:58
