Hi.
I'm trying to convert Windows Media Video files To DVD format
I tried using the following software, but it does not work.
ConvertXtoDvd - Picture looks scrambled
Xilisoft Video Converter - Will not load the file
ImTOO DVD Creator v3.0 - Will not load the file
WinAVI Video Converter - Can't decode this file! maybe broken or the relative decoder is not installed
The file is not broken as it plays on the media player!
I do not have a clue in regards to a decoder.
I would try use windows movie maker and then export to avi file that you might have better luck to convert to dvd.
Or else try also favc, dvd flick. -
Hi guns1inger
I think you could be right!
Apparently this software works FairUse4WM i'm going to give it a try, or do you know of another way?
Also thanks for your advice Baldrick! -
Definitely sounds like a DRM issue as I use ConvertXDVD all the time for WMV files without problems, but only on unprotected files. Usually you can mouse-hover over the WMV in Explorer and it will tell you if its protected or not.
another way would be to take a screen capture then convert it to mpeg
Using my laptop to capture DVD segments in WMV format
By kreskin in forum Capturing and VCRReplies: 10Last Post: 24th Dec 2011, 11:47 -
is there any way to record in wmv format ?
By Daniel_HBK in forum DVB / IPTVReplies: 1Last Post: 15th May 2010, 06:46 -
how do I join 30 .wmv files together before converting to DVD format
By dvdnewbie64 in forum EditingReplies: 3Last Post: 14th Dec 2008, 23:58 -
Settings to convert WMV to VCD/DVD-playable format?
By pingosimon in forum ffmpegX general discussionReplies: 5Last Post: 16th Jul 2007, 18:53 -
HD-DVD/BLU-RAY to HD WMV or h.264 format??? Possible???
By homerpez in forum Blu-ray RippingReplies: 8Last Post: 4th May 2007, 07:08
