Hello,
I have a bunch of old VHS tapes I want to transfer to DVD. I have my VCR hooked into my tv card. What quality should I rip the VHS tapes at so I dont lose much quality but they are easy to put on DVD? Is VCD quality good enough or must I do it in SVCD?
Thanks!
	VCD video is part of the DVD specs and can be used as-is, only the audio needs to be converted to 48kbps. SVCD is not and will require converting/reencoding. There are some methods of fooling the DVD player to think it's within spec without converting, but there's no guarantee they will play correctly on any given player.
 Only you can judge whether the quality is good enough or not."Shut up Wesley!" -- Captain Jean-Luc Picard
 Buy My Books
	Yep gadgetguy is right. VCD may be good enough for you. Do a test on a tape and find out. SVCD is not a good choice since its not dvd spec and only a few players are designed to play it natively. Best choice is either vcd on dvd or record straight to mpeg2 in a dvd mode.
 And fyi the term you are looking for is CAPTURING a vhs tape. You rip a cd or dvd. VHS is analog and you must do a realtime capture to a capture device in order to digitize it.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
  Convert all MiniDV tapes to computer and say good bye to those tapesBy iho in forum Video ConversionReplies: 38Last Post: 17th Dec 2013, 01:01
  Company that will convert my VHS tapes to computer file for me?By hubie in forum Video ConversionReplies: 8Last Post: 22nd Oct 2012, 16:37
  copy VHS tapes to computerBy pfisher in forum Newbie / General discussionsReplies: 26Last Post: 27th Sep 2010, 18:49
  I have some VHS tapes that I want to transfer to a computer hard drive.By marada in forum Capturing and VCRReplies: 15Last Post: 30th Nov 2009, 09:35
  transferring old vhs tapes to computer for editing and burning to dvdBy michael109 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Sep 2008, 12:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
