Results 1 to 16 of 16
    gold coast, australia
    After getting rid of a virus on my comp my audio has stopped working.
    On device manager it says its the Multimedia Audio Controller
    Downloaded drivers from gigabyte but hasnt changed anything
    The motherboard is a Gigabyte 8S661FXM-RZ
    What do i need to do to get audio again?
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    Have you tried redownloading your soundcard drivers? Or is this onboard audio?
    how do i find out what sound card i have?
    I used Belarc to find out what my motherboard was
    doesnt seem to be a sound card section
    says C-Media AC97 Audio Device.......would that be it?
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    The latest AC97 audio driver for your motherboard is here.
    http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1777
    i downloaded those drivers last night ...didnt help at all
    this is so damn annoying!
  6. Go into safemode and delete your soundcard from the device manager. Reboot and see if it re-detects it and fixes it.
    stupid question but
    How do i go into safe mode and disable sound card?
  8. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Restart your computer and as soon as the bios screen flash past, start hitting F8. You will be given a simple text menu and Safe Mode will be one of the options.
    Once it has booted (and this will take longer than normal), right-click on My Computer and select Manage. Click on Device Manager, find your sound card, and uninstall it. Reboot the system and see what happens.
    Do you have a TV capture or tuner card in the system at all ?
    Read my blog here.
    no i dont.
    All thats happened is that i had a msn virus, did a system restore, worked fine for a few days then the other day i booted up the computer and no audio.
    Has happened once before too, but i found the driver cd. Last time i think it was just the audio drivers off the motherboard where this time it says it is the Multimedia Audio Controller.
    Will try safe mode now
    when i go to safe mode a blank screen comes up with just the words video capture not working
    or something similar cant remember exactly
    but i cant navigate to my computer to uninstall sound card screen just freezes
    ok is says "video mode not supported"
    this is frustrating
    none of the above drivers worked and i cant uninstall
  12. boot up regular and change your resolution to 800x600 @ 60 mhz
    In order to change the mhz click advanced on the setting tab then click monitor tab clcik the down arrow
    Now see if you can boot to safe mode
    Originally Posted by jagabo
  13. stiltman I think you meant 800x600@ 60hz. 60 Mhz would be a heck of a refresh rate
    Sorry, I couldn't resist throwing that in. Slow morning at work.
    Cheers
  14. Originally Posted by TBoneit
    Cheers
    Yep! that would be a killer refresh rate wouldn't it. Sorry, just deal with Ks and Ms all day long
  15. Originally Posted by stiltman
    Cheers
    You means Usec and Msec.
    Note : Welcome to Pile-on.com
