    Sep 2007
    Australia
    Hello,
    Here is my situation.
    I have encoded a file with convertxtodvd.
    When I use mediainfo or gspot to get information on the VOB files, It shows that they are all 720 x 576 in resolution, that is not a widescreen resolution, when played back the picture should be like a square since its a 1.25 aspect ratio. When I playback the file it has a widescreen aspect ratio, more like a 720 x 400 video.
    What I do not understand is why does a 720 x 576 video looks like its a widescreen video, when the picture should be pretty square? I am confused.
    Thanks,
    Kidcash.
    Apr 2004
    Miskatonic U
    In video, pixels are not always square. 720 x 576 can represent PAL 4:3 or PAL 16:9, depending on the pixel and display resolutions used when encoding. I have also seen poorly ripped DVDs resized to 720 x 576 with a 1:1 pixel aspect ratio, giving them a distorted appearance.
    Read my blog here.
    Sep 2007
    Australia
    Ah that must be why, because the converter had to upsize the video to DVD Video Resolution which for PAL is 720 x 576, but it had to keep an aspect of the original video file in order not to distort the video.
