My brother-in-law just downloaded some footage from his Panasonic SDR-HS250 harddrive camera onto my computer. We watched it in Windows Media Player and it had sound.
I then pulled it into Video Studio 9 but there's no sound. I've had a dig around in various settings but to no avail.
The files are in Mpeg2 format. Properties of the files are as follows:
Audio Type: Dolby Digital Audio
Attributes: 48,000 Hz, 2/0 LR
Layer: None
Bit Rate: 256 kbps
Mark.
I am guessing Video Studio 9 cannot read/play AC3 (Dolby Digital) audio on it's own. You may need a plugin or to install an appropriate codec. AC3 Filter or AC3 ACM Decompressor may be required.
Read my blog here.
Thanks for that. Now, before I download & try to learn to use such a filter or decompressor (which for me as a novice is quite intimidating), would a regular Videostudio user be kind enough to confirm for sure that Videostudio doesn't support AC3 and that such a download is definitely required? That would be fantastic!
Mark.
Conversion from mpeg to mov: the sound is unsynchronized with video
By rikintosh in forum ffmpegX general discussionReplies: 4Last Post: 8th Feb 2012, 13:31 -
Corel Video Studio Pro X4 5.1 Sound Problem
By imported_kevsim in forum EditingReplies: 5Last Post: 13th Jun 2011, 18:15 -
Sound out of sync in ulead video studio..
By iames85 in forum AudioReplies: 5Last Post: 24th Apr 2011, 04:10 -
Womble Mpeg Video Wizard DVD now has no sound whatsoever
By RobertUSM in forum EditingReplies: 3Last Post: 29th Jan 2009, 07:44 -
MPEG Video Wizard exports have no sound
By cantckaja in forum Authoring (DVD)Replies: 5Last Post: 14th Sep 2008, 09:32
