I need to create flv files from a final cut pro project.
FFMpegX creates them fine if I create a quicktime using DV compression but the quality is not good enough for final use on the clients website (I think this is because the quicktime with DV compression is soft compared to an uncompressed quicktime)
When I create an uncompressed 8 bit 4:2:2 quicktime, using compressor, which looks much crisper FFmpegX cannot create a FLV from it, log report below.
Encoding started on Sun Nov 4 08:35:09 GMT 2007
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/ian/Desktop/BAA Academy-job environment new gfx-Uncompressed 8-bit PAL deinterlaced.mov':
Duration: 00:02:03.8, start: 0.000000, bitrate: 167428 kb/s
Stream #0.0(eng), 25.00 fps(r): Video: Uncompressed 8-bit 4:2:2, 720x576
Stream #0.1(eng): Audio: pcm_s16be, 48000 Hz, stereo, 1536 kb/s
Codec type mismatch for mapping #0.1 -> #0.0
This is with invert mapping selected in the audio tab, if I don't select invert mapping the process fails (See below)
Sun Nov 4 08:35:30 GMT 2007
Output #0, flv, to '/Users/ian/Desktop/BAA Academy-job environment new gfx-Uncompressed 8-bit PAL deinterlaced.mov.ff.flv':
Stream #0.0, 12.00 fps(c): Video: flv, yuv420p, 320x240, q=2-15, 200 kb/s
Stream #0.1: Audio: mp3, 22050 Hz, stereo, 56 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Unsupported codec (id=0) for input stream #0.0
Any ideas, or does FFmpeg X just not support uncompressed 4:2:2 quicktimes?
Thanks in advance for any feed back.
With decode with QT selected it creates a 0KB file in less than a second
This is the progress log
Mon Nov 5 09:35:15 GMT 2007
Thanks for the suggestion though
Originallt donw with invert mapping selected.
If I do not select invert mapping then the process fails, see log below
Encoding started on Mon Nov 5 21:05:04 GMT 2007
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
If Decode with QT still produces the "Unsupported codec"-error, then "Uncompressed 8-bit 4:2:2" isn't the right codec for this workflow.
I got working results with the supposedly lossless "Animation" codec, tho'.
I don't have Compressor, so can't do tests with this "Uncompressed 8-bit 4:2:2" you speak of.
Thanks.
Do you know of a high quality codec I can use that will produce crisp FLV's?
If I use a DV based codec the FLV looks soft, the colours loose thier punch, and there are very obvious compression artifacts. I think this is becase the DV based quicktime exported from FCP is not as good as the uncompressed 4:2:2.
Have you had a look at my other post re: strange colours on an AVI based FLV?
Any ideas on that?
Uncompressed AVI to Quicktime H264
By Simmons in forum Video ConversionReplies: 7Last Post: 3rd Aug 2011, 19:15 -
quicktime plug in for 10 bit (4:2:2) Uncompressed
By privor in forum MacReplies: 1Last Post: 24th Nov 2008, 11:29 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09 -
how to make ffmpeg recognize an uncompressed quicktime source file?
By eighth in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:09 -
Error on Uncompressed 10-bit 4:2:2 1920x1080 QUICKTIME to -> MPG
By peejeedee in forum ffmpegX general discussionReplies: 1Last Post: 12th Jun 2007, 19:04
