From DVDFab's website:
"Free DVD removes several protections from a DVD folder on the hard disk. It removes region code (RC), region code enhancement (RCE), analog copy protection, and user operation prohibitions (UOPs). You can use it to get a free DVD before you burn the DVD folder. It's only 44K."
Okay, now for the (perhaps noob) first question: How do you get a protected DVD to a folder on the hard disk in the first place?
Doesn't DVD Fab (and others) do all this this for you? Of what use is "Free DVD" and when/why would you need it?
I admit I may be overlooking the obvious . . . .
It removes other features than decryption like region protection.
edit: Oops, I didn't think in my first reply.
Windows won't let you simply copy a protected DVD to your hard drive, recognizing it as encrypted/protected data, or is there something I'm missing about a simple "copy" process?
From what I understand from these forums, to "copy" a protected DVD to a hard drive you have to use a ripper program (such as DVD Fab), and that does most (all?) of what "Free DVD" does.
So, I'm back to my original question: When/how/why would you use "Free DVD"? -
You can use it when you have a decrypted copy of DVD on your HDD but for some reason it keeps region protection code. The program detects the presence of protection and updates ifo's to remove it. It can also remove prohibited user operations (PUO's) such as skipping warning clips from remote, etc.Originally Posted by CobraPilot
Thanks, Alex_ander and Baldrick.
Assuming what you say is true, then there seems to be no obvious reason to use "Free DVD" at all, since the typical DVD rippers remove RPC, PUO's, etc., don't they?
Odd piece of software, it seems to me, but what do I know?
When you RIP a movie, all of the data is still intact on your HDD. Removing region coding and whatnot is done by reauthoring the data before you burn.
I RIP with DVDFabDecrypter, open the image with DVDShrink (which reauthors and removes protections), and then burn with Nero.
You can perform the whole process with DVDFab if you buy the full version, or in this case, it appears they have released a standalone free version for removing the copy protections.Google is your Friend -
It is certainly possible in rippers to remove region coding and PUOs (Prohibited User Operations) without having to resort to an authoring application to do so. For example DVD Decrypter can remove region coding and PUOs.Originally Posted by Krispy Kritter
Very well then. I just assumed that since the options were listed in DVDShrink, that is where the process occurred.Originally Posted by jman98
Or maybe I've just had too many drugs today and don't have a clue what I'm saying. Either way..
CheersGoogle is your Friend
"New" Best Buy DVD Player Comes With Free porn
By zzyzzx in forum Off topicReplies: 3Last Post: 25th Mar 2009, 13:41 -
Black and white picture on NTSC television from "region free" DVD
By psears in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2008, 14:00 -
How long is your "Live Free Die Hard" movie on DVD R1 ?
By NiteLite in forum Newbie / General discussionsReplies: 4Last Post: 1st Dec 2007, 17:27 -
DVD Lab Pro - Three elemenetary "hot to ....." questions
By perfection in forum Authoring (DVD)Replies: 2Last Post: 1st Sep 2007, 07:45 -
"DVD Fab - Content Removed" Is This Normal?
By heyjjjaded in forum DVD RippingReplies: 3Last Post: 21st Jul 2007, 02:19
