Results 1 to 16 of 16
    Oct 2007
    Canada
    Hi,
    My question is how do I convert .rm files to avi, mp4, or mov format with a mac?
    Thanks for your time.
  2. Try downloading the format converter from this site - http://www.dvdvideoconverter.com/mac/
    Sep 2003
    London
    They won't do rm or much else in the trialware version.
    Go off and rule the universe from beyond the grave. Or check into a psycho ward, whichever comes first, eh?
  4. Member terryj's Avatar
    N35°25.24068, W097°34.204
    My only successful way to get Real Media files into something
    useful to transcode to DVD has been to "hijack" the stream
    using iShowU to record it from Real Player 10, to DV Stream.
    Once it was done, I was able to drop that DV Stream to Toast,
    and burn it to DVD.
    Now I only had done 30 mins or so, and it was a bit choppy
    in places where there was slight re-buffering.
    But I got it to DVD.
    The same technique can be used to get an .avi or an .mp4,
    as Quicktime is the backbone for iShowU.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    May 2004
    iShowU is much less expensive than the other screen motion capture choice, Snapz Pro X, which is $70.
    If the RM file is a movie ffmpegX will convert to another format. If it's just audio, then Audacity can hijack the sound while playing, as can Wiretap Pro.
    Oct 2007
    Canada
    Thanks for the tip TerryJ. I will definitely give it a try. For some odd reason, when I try to convert with FFmpeg, it will freeze and not respond every time. Do i need anything special before I can convert .rm to other files using FFmpeg, or is it impossible for FFmpeg to do it?
  7. Member terryj's Avatar
    Follow Case's suggestion's here first.
    I haven't tried this, because it's easier for me to "hijack" the rmvb,
    but Case hasn't failed us yet.
    Urban Mac User
    Oct 2007
    Canada
    The conversion now works like a charm. Thanks for the tip Terryj. Case's way works great, but I couldn't find the right reallib codecs for intel macs until I found this https://forum.videohelp.com/topic322562.html . Once again, FFmpeg has come to my rescue.
    Thanks for everyone's help.
    Cheers
  9. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Glad it worked out.
  10. Member terryj's Avatar
    u r welcome vidhunter!
    Urban Mac User
    Nov 2007
    i'm having a problem with converting .rm to anything. whenever i click encode in ffmpegx, it just says done, and nothing happens. I installed all 3 necessary components, and the essential codecs package (then moved and renamed reallib), but it still does not work. anybody know what''s wrong?
    May 2004
    you can only use mencoder in ffmpegX for rm conversion. There are a couple of choices from the drop down menu.
    Nov 2007
    thanks, i got it working
    Dec 2007
    Slovak republic
    hi. i have still problems. i ve done everythink what i've found written here. i've installed intel binaries,ive copied codec folder to library, renamed it to reallib, ive renamed my rmvb movie so thera arent any signs anymore, its simply master.rmvb, i am encoding it to divX or Xvid preset using mencoder codec but it still doesn't work. once i get progres window working, but in it was still writting "skipping frame". and this i've made only once, all other times it just finish in one second and converted movie appierd on desktop, but it is not a converted movie. help...
    Dec 2007
    Slovak republic
    now i ve encoded it but the movie is green... and it was still writting "duplicate frame(s)!" during the progress. althought it has encoded it, it is green. could u help me whats wrong?
    Sep 2003
    London
