I would drop it into Gspot 2.70 and post a screen shot from Gspot here. There may be something obvious showing. How to post screen shots: https://forum.videohelp.com/topic271697.html
It may be at a low framerate or badly converted from a different framerate.
And welcome to our forums.
Well, that doesn't tell us everything, but it helps. It does look like it's standard PAL VCD material...
Just a thought, maybe somebody took a picture sequence and created a "video slideshow" (without any transitions) and stuck it in the standard video (aka MPEGAV/AVSEQ##.DAT) section as a sequence, instead of leaving it alone and sticking all the stills as MPEG stills in the segment section (as SEGMENT/ITEM####.DAT). IOW, they didn't know what they were doing. (they're lower rez this way, unfortunately)
You can check this (and show us) by looking at the output of the structure as seen in ISOBuster, as well as ripping the XML of the VCD PBC structure using the VCDXRip tool in VCDEasy.
If that IS the case, you'll have to export the whole show out to a series of stills. Can be done a number of ways...
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
