Hello,
I've some noise on DV Footage (some noise is normal because of lack of light) but there is some grain like on vs tapes.
What filters can improve the video (avisynth if possible) ?
Thanks.
I'm not that familiar with AVISynth, but here are a few available filters: http://avisynth.org/warpenterprises/
Mvdegrain2 located inside MVtools is great, but incredibly slow.
fft3dfilter works very well too, especially if you want to remove chroma noise - use (plane=1 or 2 for chroma)
Using reducefluctuations(limit=2) from Kassandro's ReduceFlicker plugin will calm down the image and permit you to use a less strong setting with the noise removers.
Also fast is Ttempsmooth and fluxsmooth, but it depends what your video looks like to determine if they'd be effective.
And, you can apply the noise reduction to only dark parts of the video by using this technique:
http://forum.doom9.org/showthread.php?p=1033464#post1033464 -
https://forum.videohelp.com/topic309181.html has some good discussion in it. I like peachsmoother and convolution3D. They are older filters, but the still work well.
Read my blog here.
VHS to DVD, no Picture Noise. Remuxed it, now it DOES have Picture Noise
By VideoFanatic in forum RestorationReplies: 53Last Post: 20th Sep 2011, 20:42 -
footage from 5d Mark II mixed with XLII footage
By segan in forum Newbie / General discussionsReplies: 2Last Post: 13th May 2010, 15:24 -
Removing noise from video that's possibly from aerial noise/broadcast/vhs
By filnads in forum RestorationReplies: 10Last Post: 11th Jan 2010, 01:57 -
backing up footage
By JJJewel in forum Video ConversionReplies: 5Last Post: 25th Oct 2009, 08:26 -
Video Footage, Rotating the footage.
By nikon1898 in forum EditingReplies: 2Last Post: 14th Jun 2007, 05:54
