What is the best software and codec to use to get the HIGHEST resolution, when I burn home movies to DVD for playback on home DVD player??? Thanks guys...........
Charles
So many variables have been left out of this question that need to be addressed.
In order:
* What is your source (format, resolution, Interlaced/Progressive, that sort of thing)?
* What media do you want to play it back on?
* What equipment do you wish to view it on?
* What is your level of expertise/obsession in video?
There are supplementals to each question, but these will suffice for starters.
Because with the phrasing of your question as it stands, you could get a whole heap of strange answers. If you merely wanted the highest resolution possible, you would be told to burn your source to a Blu-Ray or HD-DVD recordable, just for example. Resolution is a very source-dependent thing. If we do not know what your source is, then our ability to help you is going to be very limited at best."It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
What kind of DVD player? If it only plays DVD, then you have to use that format. Some players can also play Divx/Xvid files.
For a regular DVD, see 'WHAT IS' DVD to the upper left on this page for the DVD specifications, format and structure. You will have to follow that to create a DVD complaint file.
What format are your home movies at present? If they are from a DV camcorder, you just need a FireWire card and cable most times to get them to the computer. If they are other formats, you would need a capture device.
The 'best' software and codec is a subjective choice. Most all the MPEG encoders are capable of similar quality. It's in the codec settings where the output quality is created. Mostly from the bitrate settings. Higher is better, but higher also makes a larger file. You should be able to get about one hour of high quality video on one standard DVD-5 disc. Freeware, try HC. You can use a front end program like FAVC to encode with. Or there are plenty of payware encoders. After encoding you need to author to the DVD format, then burn to disc.
And you may be able to do all this with a DVD recorder, so you might consider that option. -
Sorry. My home player does not play Dvix. Too old I guess. Camcorder uses Mini-DV tape not HD. Used my Firewire to capture to computer. So need to get it burned to DVD now with the best picture quality. Running Vista and P4 3.06 HT 1Gb ram, 256Mb video, if this helps. Thanks for your help. New at this.
Charles -
Free:
WMM (included with Vista)
Low price:
MyDVD
Ulead DVD MovieFactory
Mid price:
Ulead VideoStudio
Pinnacle Studio
NVE
High price:
Ulead MediaStudio Pro
All of them will encode,author and burn.Just select 720x480(576 PAL) and choose the bitrate:8Mbps for 1hr or 4Mbps for 2hrs.
Software to get home movies off DVD and Burn DVDs
By Angel835 in forum Newbie / General discussionsReplies: 6Last Post: 30th Jul 2011, 22:28 -
Possible to encrypt your home movies??
By slaak in forum Newbie / General discussionsReplies: 14Last Post: 21st Jan 2010, 12:06 -
Old Home Movies
By pokereyes101 in forum Newbie / General discussionsReplies: 17Last Post: 20th May 2009, 21:05 -
How to Burn Home Movies in BLUE RAY quality?
By ozab in forum Authoring (Blu-ray)Replies: 3Last Post: 15th Jan 2009, 10:52 -
Converting Home Movies.
By Stu Pidaso in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2008, 06:21
