hi, i have an xvid with ac3 sound and need to convert the sound stream to mp3 for use on an archos av500. I was using virtual dub and simply selected 'direct stream copy' for the video then 'full processing mode' for the sound. However when I try to set the audio compression to 44,100hz @ 192kbps, the only mp3 format options that come up are all 24,000hz or lower and there is no 44,100hz options. Can anybody help? thanx
Install lame mp3. And I think you need the ac3 acm decompressor also.
ahhhh, thats the problem! There wasn't actually a lame option as it appears the version of the codec I had, had not installed properly. I have all the options now. many thanks!! However, It appeared not to have like 44,100hz and an error message came up. So i put it at 48,000hz and it started fine, is this normal?
Hybrid(Windows/Linux/Mac): Input -> x264/x265/Xvid/VP8/VP9
By Selur in forum Video ConversionReplies: 2469Last Post: 28th Apr 2026, 12:31 -
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 17:57 -
AVI/Xvid MP3 to AVI/Xvid AC3
By MarquisdeOz in forum AudioReplies: 3Last Post: 10th Sep 2010, 05:59 -
AC3 to MP3 Conversion / Synchronisation
By sjdean in forum Video ConversionReplies: 5Last Post: 18th Jul 2010, 20:25 -
DVDFab Platinum generic.xvid.mp3 audio problem
By JoeWillis in forum DVD RippingReplies: 0Last Post: 29th Aug 2007, 18:59
