System -- Vista 6.0 Build 6000 -- Athlon 4400+ -- 2GB RAM -- 2x160gb RAID -- Geforce 7800 GT -- WinTV-HVP 1600
Im trying to figure out why my video is so choppy on 1080p brodcast. I've noticed this same type of choppiness when I encoded vob's in the past. It seems to only appear on live HDTV brodcast. If I open the captured file with Windows Media Player Classic the choppy is gone. I also noticed this from other 1080i that I have gotten from other people some will play very clear and some have lines that go through them. It seems to get worse when there is motion. I should note that Im watching the video through a 1280x1024 monitor, I was thinking this could be do to resizing the video. If this is the case then WMPC must have some filter that makes the resizing smoth. If that is the case. is there any filters to add to windows media center vista or BeyondTV. that will clean this up for live brodcast.
this is my first HD tuner, I just got today. So I don't really know anything about all this. Any advice will be appreciated.
Can you check the CPU Usage under the Performance tab in the Task manager to see if it reaches 100%?
well I should have been more specific its not skipping its just have lines that make it look choppy
Just check the CPU is at 23% -
not sure what u mean by that but that sound like it discribes it
They are two differents problems,
interlace
tearing
or google for more example images. -
Yes this is it I'm getting interlacing --- well I guess I feel better that there is a name for it
No Sound Watching Live TV Windows Media Center
By rchusid in forum Media Center PC / MediaCentersReplies: 2Last Post: 25th Mar 2010, 11:41 -
media center Western Digital WD TV Live
By halekon in forum Media Center PC / MediaCentersReplies: 2Last Post: 23rd Dec 2009, 21:40 -
Windows Media Center Live tv stutters
By wh33lz in forum DVB / IPTVReplies: 1Last Post: 31st Aug 2009, 08:33 -
No Sound Live TV Windows Media Center
By Rigers in forum Media Center PC / MediaCentersReplies: 6Last Post: 5th Nov 2008, 15:04 -
No sound from live TV in Windows Media Center?!
By DonGallego28 in forum Media Center PC / MediaCentersReplies: 5Last Post: 17th Mar 2008, 13:18
