What is the conventional wisdom regarding the best way to capture realtime 3D output--from games or other software--for eventual conversion to DVD?
I've been looking at using Fraps to capture 3D on screen as none of my hardware has video-in capabilities. Are there any major pitfalls I need to look out for given that the process will involve the technically awkward task of down converting high-res progressive material to 720x480 interlaced?
Will the conversion to 720x480 interlaced have fewer artifacts if the source video is captured at as high a quality as possible (therefore allowing extensive sampling during conversion) or if the source is captured at as close to 720x480i/29.97 as is possible?
TIA.
You don't have to interlace. I would capture at 24fps and then convert to 720x480 with 3:2 pulldown, see www.videohelp.com/dvd#tech .
Transfer of real bad tape to pc and restore
By mammo1789 in forum RestorationReplies: 96Last Post: 9th Mar 2012, 23:38 -
Any such thing as an app to turn PC into real time DVD recorder?
By brassplyer in forum DVD & Blu-ray RecordersReplies: 12Last Post: 31st Mar 2010, 21:10 -
Real time video capturing
By Haopengyou in forum Capturing and VCRReplies: 3Last Post: 5th Aug 2009, 02:02 -
web cam directly to laptop dvd burner in real time? hours
By troutdavid in forum Newbie / General discussionsReplies: 1Last Post: 17th Jun 2009, 06:48 -
one step transfer DV to DVD with time and date as subtitile
By safaje in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 27th Apr 2008, 18:29
