I'm trying to convert a VOB file to mpg using Womble Mpeg Video Wizard.
I open the Export option but can't find the option of chosing a VOB file and export it as mpg...
Any ideas?
It always exports as mpeg. But to do it you have to bring it to timeline and select work range (or export 'all' by default). First drag that file to video assets tab, then drag it to timeline from there and select range if you don't want it all (in export window select 'work area' in this case, then configure other options).Originally Posted by windranger
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 03:46 -
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 20:28 -
Small help with Mpeg Video Wizard. Thanks.
By seymoria in forum EditingReplies: 3Last Post: 6th Sep 2008, 21:07 -
By newshoes in forum Software PlayingReplies: 10Last Post: 20th Mar 2008, 10:22 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 08:52
