i keep getting this error when burning a DVD9 with imgburn. does anyone know why this error is happening?
heres a pic
im using memorex DVD+R DL. some work and some get this errorOriginally Posted by guns1inger
ok thanks, but why is verbatim the only one that can make DVD DL right with no errors? i just dont understand that at allOriginally Posted by redwudz
I don't really understand it either. Verbatim apparently got the right combination and no one has seemingly been able to duplicate it. Some members have great luck with other brands. That may depend on the burner and the burning program to some extent. ImgBurn seems to be the best program to burn with at present with any burner.
All the DL discs are expensive, but I stick to Verbatim which may cost a bit more initially but I have avoided 'coasters' so far and the cost of wasted discs makes Verbatim the best bargain, IMO.
Still, try a few Verbatim DL +'s and if that solves your problem, they may be worth it to you. -
thanks for the infoOriginally Posted by redwudz
ill try some Verbatim next time
Error when burning to DVD with ImgBurn
By drkzero in forum DVD RippingReplies: 13Last Post: 4th Feb 2012, 19:07 -
ImgBurn error
By tim_ver in forum Authoring (DVD)Replies: 10Last Post: 27th Dec 2007, 17:09 -
ImgBurn I/O Error
By trunkims in forum Authoring (DVD)Replies: 12Last Post: 12th Sep 2007, 17:43 -
Imgburn Error HELP
By jessandjeff123 in forum Newbie / General discussionsReplies: 5Last Post: 10th Jun 2007, 13:42 -
ImgBurn Error?? I keep getting this...
By sandman423 in forum Authoring (DVD)Replies: 2Last Post: 2nd Jun 2007, 00:08
