I captured a MPEG-2 file from my analog TV Tuner . That file is perfectly in sync .
But if i convert the file to another format , the audio starts going out of sync as the video plays on .
I hve tried converting again and again , to the same result .
OK now wat i did is copy the streams in the original file to a new file with avidemux . The audio and video in the new file new file were out of sync. Look at the screens .
Note : The video playtime has reduced from 3:11 to 2:49 . How did this happen ?
Original File info with G-Spot and Mediainfo :
Reulting file info with G-spot and Mediainfo :
G-spot doesn't show anything .
The framerate is same in both the files , but the audio and video r out of sync .
The change in running time would explain the sync issue. The problem now is finding out why the running time has changed. The framerates don't appear to have changed. I would start by finding a different application for putting your mpg file into a transport stream container.
Read my blog here.
Using the quickstream fix in videoredo often fix mpeg2 so you can convert them after without sync problems. Videoredo is not free though so if you are looking for free alternatives you could try run the mpeg2 through projectx or pvastrumento.
But it could also be another problem.
Blu Ray slowly gets more out of sync longer you watch it... Using Leawo
By bigt85 in forum Authoring (Blu-ray)Replies: 10Last Post: 24th Jan 2012, 06:05 -
A/V goes slowly out of sync when using MKVmerge
By Tyho in forum Video ConversionReplies: 3Last Post: 10th Oct 2011, 16:55 -
A/V slowly gets out of sync using RipBot
By patmann03 in forum Blu-ray RippingReplies: 3Last Post: 7th Aug 2010, 11:32 -
Audio Slowly gets out of sync
By sirius247 in forum Video ConversionReplies: 10Last Post: 26th Jul 2010, 06:39 -
Audio drifting out slowly - Gradually goes OOS.
By blackflames in forum AudioReplies: 23Last Post: 10th Jun 2010, 06:02
