I downloaded a video from youtube. Then, i converted it to an animated GIF with media-convert.com, and when i went to play it, it plays toooo fast! How do i slow it down?
Then is media-convert not so great as you mention in your other topic, https://forum.videohelp.com/topic337663.html?highlight=animated%20gif . Have you tried any of those tools instead?
AniMagic what I use, you can go in and change delays between frames if you wish.
http://www.course.com/downloads/newperspectives/crweb2/software/Animagic/
HTH,
Andrew -
hi. thanks for the info. I found something called GIF Movie Gear, or something. It does the job well. I'll try Animagic and see if i like it better.Originally Posted by RogerTango
Well, i gave it a great rating, because it can convert almost anything you can throw at it. The downside is, it won't allow you to slow down an Animated GIF. I found something called GIF Movie Gear, and it works pretty good at slowing things down.Originally Posted by Baldrick
thanks! -
I've been using Gif Movie Gear for years.
I really like the new version because you can work with 24bit images and save as AVI or different formats instead of having to change everything to 256 color which is default for GIF images. You need to go into preferences and change the import feature to 24bit or it will open everything in 8bit, 256 color.
All gifs will be saved as 256 unless you choose lower.
Animated Gif Maker
By budwzr in forum EditingReplies: 12Last Post: 10th Jan 2012, 12:09 -
Requesting help to make an animated gif!
By kSOS in forum Newbie / General discussionsReplies: 6Last Post: 5th Apr 2010, 14:39 -
Animated Gif to Video
By MI6 in forum EditingReplies: 0Last Post: 19th Nov 2008, 04:57 -
animated gif
By snafubaby in forum Newbie / General discussionsReplies: 14Last Post: 27th Jan 2008, 14:41 -
AVI to animated GIF
By snafubaby in forum Video ConversionReplies: 10Last Post: 12th Nov 2007, 23:33
