I downloaded an avi video and when i tried burning them to nero 7 premium, only episodes 1-4 has a sound and everything else doesnt. But when i tried playing all the episodes in wmp and nero showtime its working fine, everything has sounds.. can someone please help me out.. i dont know whats missing or wrong with it. thanks so much...
Are you converting to a dvd-video? Then just try something else like favc, dvdflick or convertxtodvd.
Or are you just burning the avi files on a dvd/cd? -
Drop one of the burned files into Gspot 2.70 and see what it says about your video. Compare it with the file before burning. Several possibilities, either it didn't burn the audio or the audio ended up in a format you can't read or the audio was messed up when downloaded. What device are you playing them back on?
Software players can ignore some corruption or some missing frames in your audio/video files. But a Divx set top player may have issues with damaged files. If you have all the video and audio in the original files, you might try running them through VirtualDub and saving them out with 'Direct stream copy'. That sometimes fixes them if the problems are minor. Or re-encode them with 'Full processing' and see if that helps.
And welcome to our forums.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
nero crashed during burn
By mr-scarface in forum Authoring (DVD)Replies: 13Last Post: 14th Jan 2009, 23:41 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 21:58 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
nero burn plus subtitle?
By mai_hnf in forum DVD RippingReplies: 1Last Post: 31st Aug 2007, 23:57
