Using Sony DVD Architect 3, I have a continuous 1 hour recording of 3 episodes divided into 10 chapters. Can you help me do the following:
When played, I'd like it to revert to Main Menu when it reaches the end of Chapter 4. (episode 1)
I'd like it also to revert to Main Menu when it reaches the end of Chapter 7. (episode 2)
I don't have DVDA 3, only 4. Version 4 discusses a method using in and out points on the timeline, but I cannot make it work (DVDA claims to do a lot of things that don't really seem to work as the manual describes). If you look up Chapters in the online help, it may cover it for DVDA 3.
The best way to do what you want is to have have separate titles, not try to use chapters to create separate titles.
Failing that, you can create the disc with the chapters in place, add buttons that point to the start chapters for each segment, then use PGCEdit to change the chapter end actions to go back to the main menu. It's a lot of work though.Read my blog here.
It's the same process in DVDA3.x and 4.x -- add the movie to a menu. Then copy/paste the menu button -- notice a second version of the timeline shows up in the tree on the left. Select the 2nd timeline (copied version), and change the In/Out points. Repeat this for as many "sections" you want. NOTE: DVDA will only include the space needed for the original timeline (i.e. it does not keep eating up space each time you copy/paste the timeline).
Regards,
George -
That's what the manual says. When I tried to replicate it, I found that the in and out points that I set for button one would be set for button two, and if I changed those, the points on button one changed. I could not get different in and out points for each button.
Read my blog here.
When copy/pasting, only copy the "Original" Timeline. When changing the In/Out points, change them on the "Copied" versions of the timeline (not the original timeline).
Regards,
George
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 14:08 -
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 20:27 -
automatic chapters menu in DVD Architect
By exon in forum Authoring (DVD)Replies: 0Last Post: 18th Aug 2008, 10:10 -
Pgcedit to go to main menu after a specific chapter?
By redsandvb in forum DVD RippingReplies: 4Last Post: 15th May 2008, 20:32 -
Can't get back to main menu after movie ends
By rock_king_my in forum DVD RippingReplies: 1Last Post: 8th Dec 2007, 04:12
