Whats a good FREEWARE program that can rip an AUDIO CD to wav files![]()
Exact Audio Copy can do this. Do note that sometimes on XP that Exact Audio Copy will crash with the Blue Screen Of Death. To avoid this, after installing EAC but BEFORE you run it for the first time, go to the directory
Program Files\Exact Audio Copy
and put the file wnaspi32.dll there. Then you can safely run EAC without the BSOD. wnaspi32.dll can be downloaded for free from Nero (www.nero.com) and a few other sites - do a web search.
Note that some XP systems don't crash when running EAC without installing wnaspi32.dll first, but mine all did and it was the only thing that would stop the BSOD. Nobody seems to know why some boxes get the BSOD and others don't, so I just recommend installing wnaspi32.dll before running EAC the first time as EAC has never given me a BSOD after installing wnaspi32.dll. -
the crashing is aspi related and it relates to some software and its relation to some hd IE nero and a cd burner not cdrom. they have different drivers. you can run a program alled aspi check to see if its up to date.. you can look for aspi instal kits to make it easy or a force aspi. if you have a cd/dvd burnng software loaded and a good cd/dvd burner then you most likely wont have an issue anyway.
OH and BTW WMP will rip to wav and its free and you already have it loaded. jsut go to rip and change the format.
dBPoweramp is also free and is quite good. You only have to pay if you want MP3 encoding option (decoding is free). Large selection of codecs to choose from. CD ripping, WAV, and MP3 come with the install, other codecs are downloadable from the same site.
www.dbpoweramp.com
Relayerman -
Audiograbber is another. http://www.audiograbber.com-us.net/
-The Mang
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
6 WAV files to one 5.1 AC3... need more help please..
By RogerTango in forum EditingReplies: 17Last Post: 13th Oct 2012, 08:00 -
CamStudio AVI Files (WAV)
By foochuck in forum AudioReplies: 6Last Post: 7th Oct 2010, 19:50 -
How to merge wav files ?
By Benjy in forum AudioReplies: 7Last Post: 31st Jul 2010, 04:41 -
wav files
By BLSAMPLES in forum AudioReplies: 2Last Post: 17th Jul 2009, 13:52
