I've checked several places on this forum and can't find what I'm looking for so please accept my apology up front if I missed it:
I'm recording on a DVD-R using DVD+RW and I've reused the disks quite extensively since Christmas. The disks are starting to skip and/or pause. I was told I needed to reformat them but saw something here that says you can't do that - only erase. My DVD-R is erasing them, they're showing 100% free.
Does anyone know why the disks aren't recording cleanly anymore?...and what I can or need to do to clean them up? I was told disks should last for 10 years with no degradation, is that true?
I average about 3 disks a week and I have 6 disks so I"m reusing them every 2 weeks and I keep both the disks and the recorder clean.
Any help would be greatly appreciated.
The Operative: Are you willing to die for your beliefs?
Capt. Malcolm Reynolds: I am...'Course, that ain't exactly plan A. -
DVD+/-RW discs don't last anywhere near as the manufacturers claim. They eventually won't work at all due to the nature of how the discs are able to be erased. Eventually the crystals in them will just break down and stop working. My best advice to you would be to buy Verbatim DVD+RW discs in a spindle. They're fairly cheap. Just throw your DVD+RW discs away when they start acting up. I have even seen a Verbatim DVD+RW disc go nuts after only one write session, but usually their discs last for a while before going bad. You can also erase DVD+RW discs on a PC using burning software such as Nero provided your PC has a DVD burner on it.
Thank you very much. The whole "last for 10 years" statement seemed most illogical to me but one never knows.
I have personally noticed that when discs that have been "Quick" erased start acting up; doing a "Full" erase on your PC first, usually fixes the problem. How long this lasts, I don't know.
PS Keep in mind that even if you fully erase a disc, you may still have to do an "erase" on your stand-alone recorder prior to recording. At least this is the case on my SV2000 WV10D6. It's pretty strange how the unit knows if it's a brand new, never used disc. With new RW's, I don't have to "erase/prepare" them for use.-The Mang
How to transfer recordings on DVR to DVD
By genieboy in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2011, 22:31 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
save recordings on DVD.
By andy66 in forum Newbie / General discussionsReplies: 2Last Post: 3rd Feb 2008, 17:47 -
Help getting recordings off HD DVR onto DVD in 16:9 – not 4:3 - Please!
By ChrisU2Edge in forum DVB / IPTVReplies: 3Last Post: 12th Jul 2007, 21:43 -
1st two DVD-DL recordings failed
By DSSTBUSTER in forum DVD RippingReplies: 28Last Post: 9th May 2007, 02:23
