With tutorials and messages from here, I'm trying to learn the ins and outs of DVD file structures.
Do iDVD generated DVDs comply with the standards?
Like I'm not finding menus in the VOB files I'd suspect based on my readings and so forth.
Is it just more complex coding than I'd think, or does iDVD violate conventions to make functional, but technically wrong dvds?
As far as I know, iDVD's nav packs are compliant. You can keep it simple or put lots of interactive content in with it.
http://www.macworld.com/2006/02/reviews/idvd6/index.php
This article is older, but it explains it well enough. -
If a disc wasn't complaint it wouldn't play. Download this tool to take a look at any disc's structure:
https://www.videohelp.com/tools/myDVDEdit
DVD (full menu structure) to swf or other mobile format
By DHracer in forum Authoring (DVD)Replies: 1Last Post: 24th Dec 2010, 17:46 -
Longevity of Standard DVDs and BluRay DVDs
By bmccollum in forum MediaReplies: 10Last Post: 20th Oct 2010, 18:32 -
Make Blu Ray folder structure w/o re-copying the m2ts file
By stew181 in forum Authoring (Blu-ray)Replies: 3Last Post: 9th Jan 2010, 10:14 -
idvd and ripping dvds
By gillomax in forum MacReplies: 3Last Post: 29th Sep 2009, 10:22 -
How can i make subtitle bigger or smaller (SUP File Format)
By Charmer in forum SubtitleReplies: 9Last Post: 2nd Jun 2009, 14:43
