strange problem here my pc on first start always freezes at the windows display screen however if i press reset button on pc it will then reboot and load windows fine been hapening about a month now so this is what i have done so far
clean fans repaste chip problem is still there
memtested memory its working fine problem is still there swopped with a differnt stick problem is still there
replaced harddrive with a new one and reloaded fresh copy of windows problem is still there
replaced graphics card with another one problem is still there
swopped psu problem is still there
double checked all connections to harddrives cdroms motherboard etc problem is still there
ran seagate tools on harddrive no errors problem is still there
ran seagate tools on old harddrive no errors problem is still there
i felt for sure that by replacing the harddrive and reloading os the problem would be cured if the memory and harddrive were ok
system works perfect once it boots by the way
i can life with the problem as its only my spare pc that gets used now and again but my god its annoying me now
anyone any ideas TIA
try replacing the little motherboard battery. flat watch type silver button. it might be a loss of bios settings/reset on warm reboot. the other thing i'd check is if the memory voltage setting is correct for the ram used.
ok just cleared cmos and replaced battery ram is 2.5v as of motherbaord manual just to clarify pc has been running fine for last 5 year with the ram installed
problem persists -
One thing to try.
Go into the bios settings and look for a setting for hard drive delay. Your hard drive may be getting a little slow spinning up and adding some delay to allow for that could help.
Good Luck -
could be a failing PS too try removing as many power users pci cd dvd cards etc and see if it still does it. although by doing so it might also handle the shared IRQ problem that soopafresh is refering to.. but its a start
soopafresh i think that was a problem with win98 that went away with winXP, they handle irq's differently.
Old XP Computer Boots to Black Screen and Blinking Cursor
By p_l in forum ComputerReplies: 57Last Post: 13th Apr 2012, 13:45 -
My first attempt to backup a DVD failed...
By Inkognito in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2010, 19:07 -
PC shutsdown when I attempt to burn DVD
By steve1040 in forum ComputerReplies: 2Last Post: 21st Oct 2008, 11:10 -
Bizarre attempt to buy DvdFab
By VegasBud in forum ComputerReplies: 1Last Post: 8th Jul 2007, 21:54
