Hi there I am a complete newbie and novice at most things on the computer.
Please help with non technical help if possible.
I have a movie in a .avi format in a foreign language and I have the english subtitles in a .srt format.
How can I get the two to merge together and then burn it onto a DVD with the subtitles at the bottom of the picture.
Thanks in anticipation for the help.
Please tell me where I can find out how to do it.
AussieKev
Do you want to burn them as an avi file, for a Divx capable player, or convert it to DVD format for general DVD playback ?
For a Divx/Xvid capable player, just make sure both files have the same name, and are in the same folder. e.g. movie1.avi and movie1.srt. Burn as data, and your player will either play the subtitles automatically, or you can turn them on with the subtitle button on your remote.
To create a compliant DVD, use FAVC. Load you srt file into the subtitle area, and you will get a DVD with soft subs that can be switched on and off with the subtitle button on your remote.Read my blog here.
Make sure the movie file and the subtitle file have the same names, then load then into convertxtodvd. It will do it all automatically. Here is where you can get the software:
http://www.vso-software.fr/products/convert_x_to_dvd/You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik
Inserting subtitles in a Matroska
By Jomapil in forum SubtitleReplies: 5Last Post: 14th Apr 2012, 13:54 -
Inserting photos in a music video with movie maker
By Olustee bus in forum ComputerReplies: 0Last Post: 5th Sep 2011, 12:30 -
VisualSubSync plugin automatically inserting short blanks between subtitles
By zibizibi in forum SubtitleReplies: 1Last Post: 12th Jul 2011, 14:22 -
Inserting blank frames with logos before movie start
By multiplex in forum Newbie / General discussionsReplies: 9Last Post: 1st Oct 2008, 21:30 -
HELP!! Inserting Subtitles to an .AVI
By poopy-underwear in forum MacReplies: 5Last Post: 13th Aug 2008, 20:53
